How to enable ipv6
NethServer Version: latest stable
Hi there,
can I simply edit the ifcfg files in Network-Scripts to add an IPv6 address?
I can’t find anything in the WebGUI for that or maybe I might have just overlooked it.
Thanks,
Tony
The rule is (almost) any prop added to an interface record in networks esmith DB is transferred to ifcfg-* files in uppercase, preserving its value:
config setprop eth0 ifcfgkey1 ifcfgvalue1 [ifcfgkey2 ifcfgvalue2 ...]
signal-event interface-update
Warning: a bad configuration can lock you out of your server!
What are the required ifcfg parameters for ipv6?
/etc/sysconfig/network
NETWORKING_IPV6=yes
/etc/sysconfig/network-scripts/ifcfg-br0
IPV6INIT=yes IPV6ADDR=2001:XXXX:XXXX:XXXX... IPV6_DEFAULTGW=2001:XXXX:XXXX:XXXX...
That should be it
Tony
:thinking: I’m afraid shorewall is not configured for it… @giacomo @filippo_carletti @davide_marini could you lend an hand?
BTW @tboston is that br0 a red role? I think IPv6 can work for red only …What colour do you want to assign?
Yes thats a Red role
OK, if you don’t fear of being locked out the commands could be:
 db networks setprop br0 ipv6init yes ipv6addr X ipv6_defaultgw Y
You need to install a special rpm called for shorewall and ipv6 but I can’t recall the exact name right now.
Guess thats ‘shorewall6’ but when I install it, I can’t issue commands via WebGUI, correct?
I could try that on a local interface first I think
I wouldn’t test it on production! I’d set up a testing environment for this experiment.
hi all,
it’s me again!
Now, with my new ISP, I’ve to deal with dual STack Lite and I thought to activate IPV6 at my enp1s0(red). But as I understand, be careful…noob, in the command
I have to replace br0, X and Y by enp1s0, address and Gateway-address. But as I understand,even with IPv6 these ones could be changed anytime by my ISP.
Is there a way to handle that?
Thx allot
AFAIK IPv6 is quite used by ISP in germany…
well, noob with bad english…sorry :smile:
yes I’ve IPV6 but I’m sure that is it not static, and if I understood the Davides command it will change something in the esmith DB. So im not sure how to automatic change the tuple again if the IPV6 changed by ISP…
@davidep
so I
db networks setprop eth0 ipv6init yes ipv6addr 2a01:4f8:c0c:e221::195/64 ipv6_defaultgw fe80::1
and installed shorewall6
than reboot
now I have an IPv6
but I’m still unable to ping
ping6 google.com
ping6 2001:4860:4860::8844
both say : connect: Network is unreachable
Hello Jonathan,
You are using the nethserver localhost address as default gateway. (fe80::1)
Instead use the IPv6 address of your’e router as default gateway.
Greetings,
Henk
@helzing thank for your reply and support :wink:
but no fe80::1 is the gateway suggested by Hetzner
which works well for my Debian, Ubuntu and phontOS servers
ref: https://wiki.hetzner.de/index.php/Netzkonfiguration_CentOS/en#IPv6
Hello Jonathan,
I followed a reference from RedHat;
ref: https://www.redhat.com/sysadmin/configuring-ipv6-rhel-7-8
And this guy also explains the different IPv6 addresses with a link in his first paragraph.
I myself don’t use fixed IPv6 address, I use the autoconf and then my Nethserver has
the router IPv6 address as Gateway.
I found it
in /etc/sysconfig/network-scripts/ifcfg-INTERFACE
since the IPv6 Default Gateway is not in the same subnet
I have to specify the interface which give something like this
IPV6_DEFAULTGW=fe80::1%enp0s3
