NethServer Version: 7
Module: Webmail
Hello,
is it possible to enable automatic saving of contacts in the address book in roundcube?
Francesco
Module: Webmail
Hello,
Francesco
Hi @tecklab,
yes, this is possible with following plugin: https://github.com/sblaisot/automatic_addressbook
You may also check following link for installing plugins: http://docs.nethserver.org/en/v7/webmail.html#plugins
I like that feature too so I just tested it and it worked so far:
wget https://github.com/sblaisot/automatic_addressbook/archive/0.4.3.tar.gz
tar -xf 0.4.3.tar.gz
mv automatic_addressbook-0.4.3 /usr/share/roundcubemail/plugins/automatic_addressbook
mysql roundcubemail < /usr/share/roundcubemail/plugins/automatic_addressbook/SQL/mysql.initial.sql
config setprop roundcubemail PluginsList "managesieve,markasjunk,automatic_addressbook"
signal-event nethserver-roundcubemail-update
After sending an email, the address is saved to the âAutomatically Collectedâ address book:
hello and thanks for the support.
I tried as you say and everything works.
Thanks again
Hello
Francis
Hello,
Thanks for your share! I want to add new guide for Cpanel v80. Because cpanel Roundcube plugin directory has been changed. So,
First run following command in ssh:
Second open zipped file:
Third run following mysql command in ssh
mysql roundcube</usr/local/cpanel/base/3rdparty/roundcube/plugins/automatic_addressbook/SQL/mysql.initial.sql
Finally open following file
/usr/local/cpanel/base/3rdparty/roundcube/config/config.inc.php
Find and edit following line as below (I added automatic_addressbook in the end)
// List of active plugins (in plugins/ directory)
$config[âpluginsâ] = array(âcpanelloginâ,âcpanellogoutâ,âarchiveâ,âcalendarâ,âautomatic_addressbookâ);
Thant is all!
I am facing error at
mysql roundcubemail < /usr/local/cpanel/base/3rdparty/roundcube/plugins/automatic_addressbook-0.4.3/SQL/mysql.initial.sql
ERROR 1049 (42000): Unknown database âroundcubemailâ
welcome to Nethserver Community.
It seems you mixed the instructions for Nethserver and cpanel.
Nethserver:
cpanel:
In both cases Roundcube needs to be installed first to create the database.
As regards cpanel installation your Roundcube may have another database name.
How to install with SQLite?
Now Roundcube dont use MYSql more, data base was change to SQLite.
Can you hlp?
Hi Maximiliano (@Maximiliano_Grana_Di),
Welcome to the Nethserver Community
Are you sure you installed roundcube from the nethserver software-center?
As far as I know nethserver-roundcube setup uses mysql (mariadb) not SQLite.
Hi Mark,
I receive Roundcube with WHM and i see now default installation was SQLite and i cant changeâŠ
Di not know what WHM is; do I understand correctly you do not use nethserver?
WHM is part of CPanel it seemsâŠ
Not NethServerâŠ
Haha, @Maximiliano_Grana_Di than I can not really answer you more than a direction: you probably need to use the sqlite.initial.sql which is included in the plugin.
OK perfect. Thanks.
But Iâm sorry for my beginnerâs doubt.
How do I run this file?
My main problem is this.
Where do I run? How do I access Roundcubeâs SQLite to create these initial plugin tables?
Thank you for the patience.
I think you be better off asking your question where your cpanel/WHM is hosted.
or here ?:
Hello Friend.
I was able to figure out how to solve this problem.
With the change of the MySQL database to SQLite all stored contacts that were collected automatically were lost to my customers.
This is also an issue if you migrate your hosting account from one server to another, as âcollected contactsâ are not migrated together,
The automatic_addressbook plugin stores contacts in another table at âcollected_contactsâ.
For those interested, I made a change to the /roundcube/plugins/automatic_addressbook/config.inc.php configuration file by changing line 10 of:
$ config [âdb_table_collected_contactsâ] = âcollected_contactsâ;
for:
$ config [âdb_table_collected_contactsâ] = âcontactsâ;
This causes the âcollected contactsâ to be automatically saved âin the same locationâ as the contacts saved by the user.
In my case, this is the same, after all what matters is that the contact is âsuggestedâ when starting typing.
Another important point is that the âcollected contactsâ are now part of the customerâs address book that will be automatically backed up by WHM.
I hope this information helps.
Thanks,
Max
Hello Maz, I implemented your solution of switching to contacts but the automatic address book still does not work. could you help me ? the error.log is this
[22-May-2024 19:48:02 -0300]: DB Error: [1] no such table: collected_contacts (SQL Query: SELECT * FROM âcollected_contactsâ AS c WHERE c.âdelâ <> 1 AND c.âuser_idâ = â3â ORDER BY (c.âsurnameâ || c.âfirstnameâ || c.ânameâ || c.âemailâ) ASC LIMIT 50) in /opt/www/webmail/program/lib/Roundcube/rcube_db.php on line 577 (GET /webmail/?_task=mail&_action=list-contacts&_source=collected&_page=1&_remote=1&unlock=loading1716418082985&=1716417822555)
Thanks
