How to disable StartTLS encription on OpenLDAP connection
NethServer Version: 7.3.1611
Module: nethserver-directory
Hi All,
First, I would like to thank you for great work making NethServer solution.
I am using mine as a router and several service provider on OVH dedicated server.
What I need is to disable StartTLS encription on connections to OpenLDAP (nethserver-directory) on private (green) network side. I am able connect to directory by ApacheDirectoryStudio using ldap://privateip:389 with enabled StartTLS encription using cn=ldapservice,dc=directory,dc=nh Bind DN, but I need ability to connect to LDAP without StartTLS - just plain LDAP on 389 port.
I am completely lost in configuration how to disable StartTLS encription. Could somebody provide guide how to do it.
Thank you in advance.
You could bind anonymously! no starttls is required
Hello Davide!
Thank you for quick reply.
The client I want to integrate with LDAP is https://sandstorm.io/.
I configured anonymous bind, follow your advice and seems that the issue is at sandstorm software. Still, I am getting err=49, however other software works.
Thanks for the help.
