How to disable Oplocks
NethServer Version: NethServer release 7.6.1810 (final)
Module: File server
We have need to disable oplocks for our use-case. Can someone give me information on how to do that?
Thanks.
Ken
Nethserver uses templates for writing its configuration so to disable oplocks for any share you need to create a custom template for the default samba share profile:
Create custom template directory:
mkdir -p /etc/e-smith/templates-custom/etc/samba/smb.conf/ibay-default/
Create /etc/e-smith/templates-custom/etc/samba/smb.conf/ibay-default/91oplocks with following content:
# 91oplocks - disable oplocks
oplocks = no
Apply the config:
signal-event nethserver-samba-save
For disabling oplocks on specific shares you may use a custom samba share profile and set the SmbProfileType accordingly.
Source:
https://www.oreilly.com/openbook/samba/book/ch05_05.html
