Great to hear this ![]()
@MillerT, I encountered the same problems with VirtualBox. I investigated a bit, I think itโs a limitation of the CentOS network startup scripts when dealing with DHCP.
I โfixโ the problem with two simple commands:
db networks setprop enp0s8 role green ipaddr 192.168.56.71 netmask 255.255.255.0
signal-event interface-update
where enp0s8 is the host only adapter.
Hi Filipp0,
Thank you for the input, If I run into a problem with this (on my newer
test unit I may call on you.)
Ted Miller
C: 203-278-4606
H: 203-634-7624
