How to block specific port
is there any way to block specific port on firewall,
Yes, go to “Firewall Objects” navigate to “Services” and add the port, or “Service” you want to block, give it a name etc. Navigate to “Firewall Rules” and block that service. You can block that service or port you just created from any host or all of them, gives you a lot of options.
@Chathura_Priyasad Did you get it working? Then mark the answer as solution please?
Howto mark a topic as solved
