Regarding this thread we should try collect know how to analyze which client triggers fail2ban.
In my mind that summarize know how about:
- Some reproducible strategies to find the root causes of bans
- most common commands for analysis of the relevant log files
- prevention against the most common scenarios to lock yourself out.
I will progressively consolidate the answers here in the first posting.
Use Case #1
1. Architecture
root server within an external data center
2 network interfaces with WAN-IP (RED) and dummy LAN-IP (Green)
installed IPS, Thread Shield
own LAN with more than 30 clients behind a DSL router with dynamically changed IP address they use Nethsever for…
- authentication for some Nethserver provided applications like FileServer, DokuWiki, NextCloud, Webmail, Wordpress, VPN (Road Warrior)
2. fail2ban configuration
active jails:
- apache-auth
- apache-badbots
- apache-botsearch
- apache-fakegooglebot
- apache-modsecurity
- apache-nohome
- apache-noscript
- apache-overflows
- apache-scan
- apache-shellshock
- dovecot
- dovecot-nethserver
- ejabberd-auth
- httpd-admin
- mysqld-auth
- nextcloud-auth
- openvpn
- pam-generic
- pam-generic-nethserver
- phpmyadmin
- postfix
- postfix-ddos
- postfix-sasl-abuse
- recidive
- rspamd
- sieve
- sogo-auth
- sshd
- vsftpd
whitelisting: yes
static ban time
log level:INFO
Number of attempts: 3
time span: 10 Minutes
ban time: 15 Minutes
3. fai2ban behavior
- fail2ban bans my own LAN because one of my clients hammers against fail2ban. That’s why analysis and administration is totaly blocked
- Assumption 1: Typo within mail client logon data
- Assumption 2: user changed his own password via cockpit and the credentials within mail clients become invalid
4. work around:
- connect administrator client via mobile phone to internet to access to the root server
- whitelisting the WAN IP of the DSL-Router (unfortunately each time if DSL-Router changes his IP-address)
- preventive renewal of the mail login data for all clients, as it was not possible to identify the triggering client quickly
5. Analysis Procedure:
- Identify banned IP and whitelist and unblock it if it is identical to your own WAN IP
- Determination of the applicable jail / service and trigger time
- Determination of the applicable local client
- tbd
6. Analysis commands:
6.1 Analysis of triggerd jails
# cat /var/log/fail2ban.log | grep "Ban my.dynamic.wan.ip"
6.1 Analysis of current postfix/smtpd jail
# fail2ban-regex /var/log/maillog /etc/fail2ban/filter.d/postfix.conf --print-all-matched
# fail2ban-regex /var/log/maillog /etc/fail2ban/filter.d/postfix-ddos.conf --print-all-matched
6.2 Analysis of earlier postfix/smtpd jail
# fail2ban-regex /var/log/maillog-yyyymmdd /etc/fail2ban/filter.d/postfix.conf --print-all-matched
# fail2ban-regex /var/log/maillog-yyyymmdd /etc/fail2ban/filter.d/postfix-ddos.conf --print-all-matched
Matrix of log files corresponding to jails
| Jail | Logs |
| apache-auth | /var/log/httpd/*error_log |
| apache-badbots | /var/log/httpd/access_log |
| apache-botsearch | /var/log/httpd/*error_log |
| apache-fakegooglebot | /var/log/httpd/access_log |
| apache-modsecurity | /var/log/httpd/*error_log |
| apache-nohome | /var/log/httpd/*error_log |
| apache-noscript | /var/log/httpd/*error_log |
| apache-overflows | /var/log/httpd/*error_log |
| apache-scan | /var/log/httpd/*error_log. |
| apache-shellshock | /var/log/httpd/*error_log |
| dovecot | /var/log/imap |
| dovecot-nethserver | /var/log/imap |
| ejabberd-auth | /var/log/ejabberd/ejabberd.log|
| httpd-admin |/var/log/httpd-admin/access_log|
| mysqld-auth | /var/log/mariadb/mariadb.log |
| nextcloud-auth |/var/lib/nethserver/nextcloud/nextcloud.log |
| openvpn | /var/log/openvpn/openvpn.log |
| pam-generic | /var/log/secure |
| pam-generic-nethserver | /var/log/secure |
| phpmyadmin | /var/log/httpd/access_log |
| postfix | /var/log/maillog |
| postfix/smtp | /var/log/maillog |
| postfix-ddos | /var/log/maillog |
| postfix-sasl-abuse | /var/log/maillog |
| recidive | /var/log/fail2ban.log |
| rspamd |/var/log/httpd-admin/access_log|
| sieve | %(dovecot_log)s |
| sogo-auth | /var/log/sogo/sogo.log |
| sshd | %(sshd_log)s |
| vsftpd | /var/log/vsftpd.log |
| webtop |/var/log/webtop/webtop_auth.log|
Please correct and add with your suggestions.
