I have started to translate NethServer to Polish language via transifex. My question is how to add this translation to NethServer to check if they are correct?
Hi Dominik, you can download language catalogs from Transifex with
tx pull -l <LANG> -a
Then move the files under
/usr/share/nethesis/NethServer/Language/<FULL_LANG>
LANG should be “pl”, FULL_LANG “pl_PL” (but I can be wrong…)
I’m sorry for plural forms: they’re not available
Thank you - i will try this
