How the forum works?
Is there anywhere a description how this forum is working? I’m thinking about a central point where to find
  • an index of badges
  • which forum-software is used
  • how to post for example bold text or code
; Maximum size of POST data that PHP will accept.
; Its value may be 0 to disable the limit. It is ignored if POST data reading
; is disabled through enable_post_data_reading.
; http://php.net/post-max-size
; default: post_max_size = 8M
post_max_size = 100M
  • what does the trust levels mean
  • an overview about all categories with description.
I know the most points are already described, but I mean at one central point.
PS: A description about trust-levels I found here:
Well, the basic formatting things (bold, italic, links) are done in the editor toolbar, but preformatted text is a notable exception–and getting it to preformat without doing the (apparently-random) syntax highlighting is more obscure yet. There really should be a link from the editor window to a guide to the formatting syntax, especially since it doesn’t use bbcode, like just about every other forum in existence.
Honestly not a big fan of Discourse, but it does seem to be teh new hawtness in forums.
You can find all the badges here
https://community.nethserver.org/badges
Is it necessary?
Discobot helps every new user to use Discourse
You’re right :slight_smile: would you mind creating a new post collecting all needed info?
If you want to know how to format a post and you can’t find it at the description you can search by Google with the name of the forum-software
Can I ask him to send the PM again?
I can try to collect some points, but some things I didn’t know also, for example how to show other people how to post code.
Sorry guys,
I forgot to post the Link to the Howto. Here it is:
