Can you explain how one can track threads?
See the bottom of the topic, you can find the same options watch/track/mute. The behavior is the same. When you reply or read a topic then it’s automatically flagged as watching.
Please play with it wink it’s simple I think…
I asked that you explain for everyone else
Tracking doesn’t help to understand what it means? Do you expect people to get it normally?
Which part is not clear? Looks pretty straightforward to me
I have to check
Cheers,
Horace
