how create certificade VPN with OpenVPN
Hi @kristian1369,
for next time it would be nice, if you can give us some more infos. We don’t know if you you want to connect a client to a server or if you want to connect two servers. Also setting the group (Support) and a category (VPN, OpenVPN) could help, that more people read your post and can help.
The next points are an instruction for a client connection.
- Install VPN from Software-Center
- Go to Applications and choose
Settingsat the VPN application - Choose
OVPN Roadwarriorat the menu and enable it. - Make your settings. At
Auth-Modeyou can choose your Authentication, for example certificate, certificate and password… - Create users
