NethServer Version: 7.6
Module: nethserver-hotsync
I reinstalled Neth on the system that’s been my hotsync target, and now hotsync isn’t working any more–I’m getting an email every 15 minutes saying:
hotsync error: rsync returned 12. rsync output:
rsync: safe_read failed to read 1 bytes [sender]: Connection reset by peer (104)
rsync error: error in rsync protocol data stream (code 12) at io.c(276) [sender=3.1.2]
Configuration appears to match. Here’s the master:
[root@neth ~]# config show rsyncd
rsyncd=service
TCPPort=873
password=(redacted)
status=disabled
[root@neth ~]# config show hotsync
hotsync=configuration
MasterHost=
SlaveHost=192.168.1.60
SlavePort=273
databases=enabled
role=master
status=enabled
[root@neth ~]#
…and on the target:
[root@neth-backup ~]# config show rsyncd
rsyncd=service
TCPPort=873
password=(redacted)
status=enabled
[root@neth-backup ~]# config show hotsync
MasterHost=192.168.3.100
SlaveHost=
SlavePort=273
databases=enabled
role=slave
status=enabled
Each system can ping the other at the IP address in the database. This was in the system log at the time of the last failure:
Aug 25 17:30:32 neth esmith::event[14340]: Event: pre-backup-config
Aug 25 17:30:32 neth esmith::event[14340]: expanding /etc/backup-config.d/nethserver-sssd.include
Aug 25 17:30:32 neth esmith::event[14340]: WARNING in /etc/e-smith/templates//etc/backup-config.d/nethserver-sssd.include/20kerberos: Use of uninitialized value in string ne at /etc/e-smith/templates//etc/backup-config.d/nethserver-sssd.include/20kerberos line 5.
Aug 25 17:30:32 neth esmith::event[14340]: WARNING: Template processing succeeded for //etc/backup-config.d/nethserver-sssd.include: 1 fragment generated warnings
Aug 25 17:30:32 neth esmith::event[14340]: at /etc/e-smith/events/actions/generic_template_expand line 64.
Aug 25 17:30:32 neth esmith::event[14340]: Action: /etc/e-smith/events/actions/generic_template_expand SUCCESS [0.160081]
Aug 25 17:30:32 neth esmith::event[14340]: Action: /etc/e-smith/events/pre-backup-config/S20nethserver-directory-dump-ldap SUCCESS [0.073252]
Aug 25 17:30:32 neth esmith::event[14340]: Action: /etc/e-smith/events/pre-backup-config/S40nethserver-mail-shrmbx-cfgbackup SUCCESS [0.011093]
Aug 25 17:30:32 neth esmith::event[14340]: Action: /etc/e-smith/events/pre-backup-config/S40nethserver-sssd-backup-tdb SUCCESS [0.004206]
Aug 25 17:30:37 neth esmith::event[14340]: Action: /etc/e-smith/events/pre-backup-config/S50nethserver-backup-config-list-packages SUCCESS [4.706979]
Aug 25 17:30:37 neth esmith::event[14340]: Event: pre-backup-config SUCCESS
Aug 25 17:30:37 neth esmith::event[14377]: Event: post-backup-config
Aug 25 17:30:37 neth esmith::event[14377]: Event: post-backup-config SUCCESS
…but it doesn’t look relevant. I don’t see any other log files that look like they’d be helpful. What else should I be checking?
