Can i change the original home folder to /root/mycompany folder in order to easy access of ibays and other user folders
It’s possible, you’ll have to link the folders to the original location. I did that and moved all the home and share folders to a RAID 5 disk.
You can also use mount with --bind options
Actually, come to think of it; that’s what I did. It preserves ownership whereas linking doesn’t.
please define “easy access”, because your question makes no sense to me…
there’s no reason to change phisycal location/mount point of home dirs as long as you know where they are and access them via clients
finally, explain your problem and not your solution, thank you
I mean, if we mount a ibays we have to type long path every time. If we can move ibays to up it is easier i think.
an ibay is shared as yourserver\ibayname
so, again, where do you have to “mount” your ibay so that its path is an issue?
/mycompany on the root
ns_nirosh, your answer, once again, makes no sense…
what are you trying to achieve? the whole plot, please, thank you
I try not to archive. Try to copy and paste some files to and from user accounts. Bcos each user account is visible only to specific user only.
