Does anybody use a Highpoint RocketRaid 2710 or any similiar raid card? The thing is that I would like to have Nethserver 6.7 on the raid, but the pre-built drivers Highpoint is providing are for CentOS versions 5.8, 6.3 and 7.0 (no 6.7). Does anybody have a similiar issue or does anybody know a reasonable workaround to this problem?
cheap raid controller means a fake raid card: don’t need it, don’t use it
you don’t really need an hw raid card if you can’t afford the price
just use the sw raid: affordable, reliable, easy to administrate, fast enough (on modern hw you won’t notice the difference… well… on a 10 disks raid6 maybe )
