Help with VLAN setup
This is what I get with the above settings and tests.
And this is what I get just by enabling dhcp on interface eno2.0
Keep in mind I said I was pretty much clueless so I thought all I had to do was create the vlan, and enable dhcp on and I was all set. I put a fresh copy of nethserver on it and all I did was get thru the setup and then configured my interfaces nothing else.
Thanks for hanging in there with me.
I got it working!!! Yay, hallelujah. I read somewhere to never use vlan1 for anything. So I setup vlan 10, 20, and 30 with 192.168.1,2,3 respectively. Turned on dhcp for each vlan, went in the switch and split up the ports and tested each group of vlans to verify dhcp.
One thing I did notice, I can ping outside network to other vlans, is this normal?
I’m now aware of such limitation, hope @filippo_carletti or @davide_marini would shed the light on it
Hello admsjsas can you put an schema and the steps you have done please switch also.
Best regards
