Does anyone have links or suggestions on how I can monitor my Proxmox Hosts and PBS servers using Zabbix? I currently monitor the hosts themselves using Zaabix Agent 2 using the General Linux Template. But I’m looking to extend my monitoring to the following:
status of backups (success or fail)
status of proxmox jobs such as prune, verify or sync
Hi also I use Zabbix to monitor the pbs and proxmox server. I’m trying to expand the information, I know there are some templates on the zabbix share store.
Hi I don’t know, I use 7 and with the agent installed I have the information base. Clearly, like you, something advanced awaits her but this is what I found. If you want, you can test everything in my entire test environment, but now I can’t. I have untying a three node with PBS for i.
Hi, I quickly tried the template. It gets uploaded to the zabbix server but I can’t see anything at the moment. Also, the template is designed to work with VMS and not PBS! I plan to try again as soon as possible.
AFAIK, at the moment, there’s still no dedicated module for Zabbix / PBS…
Probably PBS is too new, and has moved forwards so fast with a LOT of major changes between 1.0 and the present 2.0.9…
To get decent, valid data for PBS in Zabbix, one needs to use a couple of scripts, maybe in combination with mails about errors / successful completion of backups…
The PVE API has pvesh commands to help with gathering information from our PVE server. But their doesn’t appear to be similar commands for PBS. But there are HTTP commands but I don’t know how to execute them to find the details I need.
Are there any programmers here at Nethserver (perhaps @mrmarkuz or @stephdl) who may know how to extract details from PBS to be put into a script for the beginning of a Zabbix template?
