Hi guys, I know this is completely offtopic for nethserver, but we have quite some decent coders in our community. So I thought, maybe any of you can help this non-coder with creating a script to daily scrape a html table from a website. The Url of the website is always the same
The table has a clear table definition in a div
The table header is always the same:
< div class=“text”>
< table class=“table table-striped” cellspacing=“0”>
< thead>
< tr>
< th>Column one
< th>Column two
< th>Column three
< th>Column four
< /tr>
< /thead>
The table contents is updated every day and can contain the same content as the previous day. There also can be new rows added.
The table body is between
< table>
< tbody>
< /tbody>
< /table>
tags
The table is not the only contents of the webpage.
Ultimately I would like the script to be a cron job on my NethServer server and store the output as a csv with timestamp as name.
Thanks so far.
I was fiddling with libreoffice calc and I can download the table:
Go to the Sheet tab in the menu,
click “Link to external data”
type in the URL of the webpage containing the table
at importoptions, just hit enter
Next window is select available Tables/ranges
select the first table: HTML_1 and hit enter
The table is downloaded and imported in Libreoffice Calc.
BUT, this is not going to be very useful when I need this to be done on a daily basis on a set time…
@m.traeumner where is the output of the curl command going? Should I just add a -o {timestamp}.csv or something like that?
When I change the url to the url I need I don’t get any output at all (not to terminal)
Could that be that the sed / awk foo needs tweaking to exactly the website format?
Cool idea, but doesn’t work for a lot of HTML files. Mine have the data inside the table on its own line (i.e. <td>\ncell value\n</td> ), and this script ends up stripping out that data because it removes every line that doesn’t have a table tag in it.
Perhaps this is the problem. I think you could analyse your html site and have to change the sed-settings.
I think it’s not the html format, it’s the table format.
I don’t know sed too, but I’ve found something interesting.
You could try to save the html file with curl -o table.html and the sed command has to have an input and output file:
sed ‘s/one/two/g’ inputfile outputfile
The option s is for search a string. In this example one
The g option is two replace it. Here one is replaced with two.
How do I send the output to a new file with a timestamped name? Something like output{timestamp}.csv (the out put already will be in some kind of delimiter since it already is a table on the webpage)
I didn’t try, I think there are some mistakes, but you can try this:
Date and Time you can get with
// Get Date and Time as a String and write it to $date
$date=date("Y-m-d-H-i");
Saving the file should look like this:
//creating the filename and an emty data variable
$filename="output" . $time;
$data=""
// create the file
file_put_contents ( $filename , $data);
// Navigate the tree
$li = $dom->getElementById('menu-item-112');
$children = $li->getElementsByTagName('span');
foreach ($children as $child) {
// echo $child->nodeValue."\n";
// Opens the file
$current = file_get_contents($filename);
// Add new content
$data .= $child->nodeValue."\n";
// Write back to the file, not overriting the old content
file_put_contents($filename, $data, FILE_APPEND);
Data should be the content of the file which you should get from @giacomo’s script. I think
