Hello LayLow
yes i will but yesterday was 2 late i will strart again this weekend. But TaxOffice is calling 4 papers
Hello LayLow
Hello Markus
I will try it again 2morrow. So ther is nothing 2 do on the NethserverAdminWebSide?
Weekend and i try again the Quickinstall again in a XCP-NG VM, and i looks differend to the friest two trys
A lill bit more packages … I am saving the list of packages. Now 2 the Nextcloud config…
I am starting with
config setprop fw_onlyoffice host 1.2.3.4 (with the IP of my Nethserver)
sorry there was something be4
[root@neth ~]# config setprop fw_onlyoffice RejectUnauthorized false
[root@neth ~]# config setprop fw_onlyoffice host 192.168.38.10
I hope was not so bad
signal-event nethserver-onlyoffice-update
https://192.168.38.10:8082/welcome/
Document Server is running
same result like the first try
Some Logfiles 2morrow … or in the morning
Please check
/var/log/onlyoffice/documentserver/docservice/err.log
/var/log/onlyoffice/documentserver/docservice/out.log
/var/lib/nethserver/nextcloud/nextcloud.log
good Morning
a cup of tee and than try again
first the self made cert was changed, must reload it in firefox.
I working strictly with the Quickinstall .
Than
at the end
https://192.168.38.10/nextcloud/index.php/login
I had the Login
But is “fresh” no Users and Groups
/var/log/onlyoffice/documentserver/docservice/err.log is emty
[2019-01-12T01:02:10.222] [WARN] nodeJS - Plugins watch exception (https://nodejs.org/docs/latest/api/fs.html#fs_availability).
[2019-01-12T01:02:10.326] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:10.538] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:10.882] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:11.468] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:12.453] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:14.134] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:16.987] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:21.831] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:30.044] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:02:44.012] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:03:07.747] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:03:48.095] [ERROR] nodeJS - redisClient error Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED 127.0.0.1:6379
[2019-01-12T01:05:00.020] [WARN] nodeJS - Plugins watch exception (https://nodejs.org/docs/latest/api/fs.html#fs_availability).
[2019-01-12T01:05:00.142] [WARN] nodeJS - update cluster with 1 workers
[2019-01-12T01:05:00.213] [WARN] nodeJS - worker 82624 started.
[2019-01-12T01:05:00.213] [WARN] nodeJS - update cluster with 1 workers
[2019-01-12T01:05:03.404] [WARN] nodeJS - Express server starting...
[2019-01-12T01:05:06.201] [WARN] nodeJS - Express server listening on port 48000 in production-linux mode
[2019-01-12T01:16:44.543] [WARN] nodeJS - Plugins watch exception (https://nodejs.org/docs/latest/api/fs.html#fs_availability).
[2019-01-12T01:16:44.642] [WARN] nodeJS - update cluster with 1 workers
[2019-01-12T01:16:44.691] [WARN] nodeJS - worker 94199 started.
[2019-01-12T01:16:44.692] [WARN] nodeJS - update cluster with 1 workers
[2019-01-12T01:16:47.858] [WARN] nodeJS - Express server starting...
[2019-01-12T01:16:50.641] [WARN] nodeJS - Express server listening on port 48000 in production-linux mode
/var/lib/nethserver/nextcloud/nextcloud.log is emty
[root@neth ~]# cat /etc/nginx/conf.d/onlyofficedocumentserver.conf
cat: /etc/nginx/conf.d/onlyofficedocumentserver.conf: No such file or directory
but /etc/nginx/conf.d/onlyoffice-documentserver.conf is there
## HTTPS host
server {
listen 0.0.0.0:8082 ssl;
listen [::]:8082 ssl default_server;
server_tokens off;
root /usr/share/nginx/html;
## Strong SSL Security
## https://raymii.org/s/tutorials/Strong_SSL_Security_On_nginx.html
ssl on;
ssl_certificate /etc/pki/tls/certs/localhost.crt;
ssl_certificate_key /etc/pki/tls/private/localhost.key;
ssl_verify_client off;
Does it work now?
The errors and warnings are ok, I have the same on my machine and it’s working.
You may login as Nextcloud admin with username admin and password Nethesis,1234
NextCloud Log with amin was okay
That is okay and under Nextcloud Apps Onlyoffice is running
This side say : DokumentServer is runnig
That the way 2 get the GUI from Onlyoffice with a login ?
In Nextcloud you need to open an office document or create one with the “+” button.
sometime the world is simpel when soboby know how simpel
on https://neth:8082 is only the status of the Doc-Server
and open up the Docs directly
very easy! but 2 easy for a oldfashion IT Guy
the was some missunderstanding like mine in the community
will be nice when you add a few line in your very good HowToDo
Like the this
First use Onlyoffice
Login in Nextcloud
loadup a document or use Nextcloud -> files -> (+) new Document
Than Nextclout will oben up Onlyoffce with your doc …
THX 4 Help and looks like great work
Now with real user test build user an PW and retry
Internal its running perfect (local Intranet)
Now its running very nice software a a good integration
My testing Plattform is a XCP_NG 7.6 Server with 16G RAM and a AMD Phenom™ II X4 965 Processor 3.4 GHz.
The VM was running with 4G RAM an 1 CPU. When i am testing one CPU was on 100%, but system was working fine. After reboot CPU was lower. Them I try 2 Cores and 6GRam now both CPUs ar on 40% with OnlyOffice 60%…
But most preformance neeeds Nextcloud…
Thx only a information 4 Users with 100% CPU consumtions. The infos are reading from XCP_NG Host
Hello
Yes or tried with self-signed certificates and without, but the problem remains how can I do to solve the thing where I’m wrong
I have to use it both in Local and in remote
For using onlyoffice with a self-signed certificate you have to allow the document server page in your browser. (I tested with Firefox)
Browse to https://NETHSERVER:8082 and allow the site in your browser otherwise the documentserver may not work.
The recommended way is to use a letsencrypt cert and always use https://domain.tld/nextcloud
instead of a local address, so you don’t have to care about the browser settings.
config setprop fw_onlyoffice RejectUnauthorized ''
config setprop fw_onlyoffice host domain.tld
ok:kissing_heart:
