Hi guys! Need help in configuring the proxy. There are two virtual networks on one of the network cards. Look both in the local network. For example 192.168.2.2 / 24 and 192.168.10.2 / 24. I can choose between the blue and green areas. In the settings section netnserver proxy selection mode only proxies for established networks. The question is - is it possible to enable the proxy only on the same network? Is it possible to do so?
