So I need the reverse proxy to redirect this URL to the internal URL: https://server1/SOGo
I’ve found this very nice post but unfortunately… I don’t understand what needs to be done and I feel that because it’s not exactly the same use-case it doesn’t apply (I think my use case is simpler).
And if possible I would like to be able to do that with the UI
Here’s what I’ve done so far:
redirect 80/443 traffic to frontend1
request letsencrypt certificate for mydomain.net from frontend1
add virtual host for mydomain.net on frontend1 (though I’m not sure it’s useful).
Now I’m completely struggling with the reverse proxy definition. (I used to use Caddy as a reverse proxy in my previous setup and it was very easy to define but for some reason it doesn’t work with NS.)
First of all, I think there’s a bug in the reverse proxy interface. I will log one accordingly but if anyone has experience in doing what I try, it would be welcome!
Unfortunately if I do that I will redirect all the http traffic to server1, and this is not what I want as I want to point to different servers depending on the subfolder.
