Help Backup Error
(Antonio) #1
Hello everyone who gives me a hand to solve this pproblema, by Sunday, 01/03/2016 I get the following error:
===== Report for data backup =====
Backup started at 2016-01-03 20:00:08
Backup script status: ERROR
Extract from log file /var/log/backup-data.log:
2016-01-03 20:00:08 - START - Backup data started
2016-01-03 20:00:21 - STEP - pre-backup-done done
2016-01-03 20:03:35 - ERROR - Backup failed, see /var/log/last-backup.log for details - 13568
2016-01-03 20:03:35 - ERROR - Action backup-data-duplicity failed - 1
Extract from log file /var/log/last-backup.log:
Import of duplicity.backends.dpbxbackend Failed: No module named dropbox
Reading globbing filelist /tmp/qbX233Gvn7
Local and Remote metadata are synchronized, no sync needed.
Last full backup left a partial set, restarting.
Last full backup date: Sat Jan 2 21:00:45 2016
RESTART: Volumes 22 to 22 failed to upload before termination.
Restarting backup at volume 22.
Restarting after volume 21, file var/www/html/owncloud/data/interventotecnico/files/WIFI4ALL/Manutenzioni/Manutenzione 17672 UFFICIO SERVIZI CONTABILI LIVIERI DANIELA/2015-06-23 10.59.42.3gp, block 45
File var/www/html/owncloud/data/interventotecnico/files/WIFI4ALL/Manutenzioni/Manutenzione 17672 UFFICIO SERVIZI CONTABILI LIVIERI DANIELA/2015-06-23 10.59.42.3gp complete in backup set.
Continuing restart on file var/www/html/owncloud/data/interventotecnico/files/WIFI4ALL/Manutenzioni/Manutenzione 17672 UFFICIO SERVIZI CONTABILI LIVIERI DANIELA/2015-06-23 11 00 06.zip.
[Errno 28] No space left on device
what should I do to solve
Thank you in advance
(Gabriel GHEORGHIU) #2
Hi Antonio,
Check free space on the backup device.
It seems that the backup device is full or the file size is too big.
(Artem Fedai) #3
Hi @k1000 ,
It is preferable to make incremental backup.
As to Backup module @giacomo and @filippo_carletti we should somehow exclude “/mnt” or network device folder from backuping, because some people use it and backup module backing up whole system folders and that is why backup becomes double sized.
To avoid this situation we need to add exclusion to :
http://docs.nethserver.org/en/latest/backup.html#id2
/etc/backup-config.d/custom.exclude
(Antonio) #4
ok
OK … J
J
(Alessio Fattorini) #5
Do you have resolved? Could you mark the correct answer?
(Antonio) #6
you will excuse me everything was ok now full disk BIG THANK you
(Alessio Fattorini) #7
2 posts were split to a new topic: Backup Input/output error
