HeloHost issues multiple domains or disabling
mailserver
v7
(Loren Tedford (Kc9Zhv)) #1
I have finally gotten neth 7 working correctly in our new location and now that we don’t have funky ip gateway settings things are going much smoother.
Helohost is putting my ip as a spam what ever on some spam watch dog things…
so i have multiple domains how do i add multiple domains on this or completely disable helohost altogether.
Here is what i thought the command did.
config setprop postfix HeloHost 157.185.79.38 lorentedford.com ltcraft.net ilhamradio.org kc9zhv.com kc9zhr.com voipham.com mdsucks.com newwavesucks.com
signal-event nethserver-mail-common-save
Is this how it works? or can i just disable it completely?
(Markus Neuberger) #3
Usually you’d just need one resolvable hostname.
If it doesn’t work with HeloHost you may try this:
(Loren Tedford (Kc9Zhv)) #4
So does this mean in place of Banner Host I put each domain or how does this work? I am a bit confused.
(Markus Neuberger) #5
You only need one domain.
(Loren Tedford (Kc9Zhv)) #6
Ok thanks I will try this!
(Loren Tedford (Kc9Zhv)) #7
So for some reason or another it didn’t work i got a message where it felt like my ip needed blocked. It requested that i put the ip in boxed [192.168.0.0] <- Example of how it looked. Brackets… what is CBL anyway also it keeps leading me back to this site.
https://www.abuseat.org/lookup.cgi?ip=157.185.79.38
(Markus Neuberger) #8
Maybe you changed the banner in a wrong way, you should use an FQDN like mailserver.domain.tld.
To check your banner (exit with CTRL-C):
cat < /dev/tcp/127.0.0.1/25
(Loren Tedford (Kc9Zhv)) #9
Here is what i got…
[root@webserver ~]# cat < /dev/tcp/127.0.0.1/25
220 webserver.lorentedford.com ESMTP Postfix
^X^C
[root@webserver ~]#
Also according to Name Cheap under DNS it should be even pointed to the right location.
So not sure what is up.
(Markus Neuberger) #10
It should be mail.domain.com instead of webserver.domain.com.
You may check for mail server problems with mxtoolbox, here is a tutorial for setting up mail:
https://wiki.nethserver.org/doku.php?id=email_protection_resources
