NethServer Version: 7.6
Module: SoftwareCenter update
hello
I had a problem with the normal softwareupdate. The softwarecenter says ther are updates. i try it with out sucess.Software Center told me erase the Yum Cache. next try, same results…
If i try yum from the commandline, i get this errormassages.
Dind anybody had a Idea ?
→ Finished Dependency Resolution
Error: Package: 1:npm-3.10.10-1.6.16.0.1.el7.x86_64 (epel)
Requires: nodejs = 1:6.16.0-1.el7
Removing: 1:nodejs-6.14.3-1.el7.x86_64 (@epel)
nodejs = 1:6.14.3-1.el7
Updated By: 2:nodejs-8.15.1-1nodesource.x86_64 (nodesource)
nodejs = 2:8.15.1-1nodesource
Available: 1:nodejs-6.16.0-1.el7.x86_64 (epel)
Available: 2:nodejs-8.0.0-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.0.0-1nodesource.el7.centos
Available: 2:nodejs-8.1.0-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.1.0-1nodesource.el7.centos
Available: 2:nodejs-8.1.1-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.1.1-1nodesource.el7.centos
Available: 2:nodejs-8.1.2-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.1.2-1nodesource.el7.centos
Available: 2:nodejs-8.1.3-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.1.3-1nodesource.el7.centos
Available: 2:nodejs-8.1.4-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.1.4-1nodesource.el7.centos
Available: 2:nodejs-8.2.0-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.2.0-1nodesource.el7.centos
Available: 2:nodejs-8.2.1-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.2.1-1nodesource.el7.centos
Available: 2:nodejs-8.3.0-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.3.0-1nodesource.el7.centos
Available: 2:nodejs-8.4.0-1nodesource.el7.centos.x86_64 (nodesource)
nodejs = 2:8.4.0-1nodesource.el7.centos
Available: 2:nodejs-8.5.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.5.0-1nodesource
Available: 2:nodejs-8.6.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.6.0-1nodesource
Available: 2:nodejs-8.7.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.7.0-1nodesource
Available: 2:nodejs-8.8.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.8.0-1nodesource
Available: 2:nodejs-8.8.1-1nodesource.x86_64 (nodesource)
nodejs = 2:8.8.1-1nodesource
Available: 2:nodejs-8.9.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.9.0-1nodesource
Available: 2:nodejs-8.9.1-1nodesource.x86_64 (nodesource)
nodejs = 2:8.9.1-1nodesource
Available: 2:nodejs-8.9.2-1nodesource.x86_64 (nodesource)
nodejs = 2:8.9.2-1nodesource
Available: 2:nodejs-8.9.3-1nodesource.x86_64 (nodesource)
nodejs = 2:8.9.3-1nodesource
Available: 2:nodejs-8.9.4-1nodesource.x86_64 (nodesource)
nodejs = 2:8.9.4-1nodesource
Available: 2:nodejs-8.10.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.10.0-1nodesource
Available: 2:nodejs-8.11.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.11.0-1nodesource
Available: 2:nodejs-8.11.1-1nodesource.x86_64 (nodesource)
nodejs = 2:8.11.1-1nodesource
Available: 2:nodejs-8.11.2-1nodesource.x86_64 (nodesource)
nodejs = 2:8.11.2-1nodesource
Available: 2:nodejs-8.11.3-1nodesource.x86_64 (nodesource)
nodejs = 2:8.11.3-1nodesource
Available: 2:nodejs-8.11.4-1nodesource.x86_64 (nodesource)
nodejs = 2:8.11.4-1nodesource
Available: 2:nodejs-8.12.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.12.0-1nodesource
Available: 2:nodejs-8.13.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.13.0-1nodesource
Available: 2:nodejs-8.14.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.14.0-1nodesource
Available: 2:nodejs-8.14.1-1nodesource.x86_64 (nodesource)
nodejs = 2:8.14.1-1nodesource
Available: 2:nodejs-8.15.0-1nodesource.x86_64 (nodesource)
nodejs = 2:8.15.0-1nodesource
Last Update was second of february.
with
yum update --skip-broken
the update is running waiting for results …
more later …
mostly are okay but
Skipped (dependency problems):
nodejs.x86_64 2:8.15.1-1nodesource npm.x86_64 1:3.10.10-1.6.16.0.1.el7
any Idea?
thx Axel
