Since about 2 weeks I’m having problems with Guacamole, it seems al my 20+ NethServers with Guacamole 1.1 aren’t working anymore…
All were working, tested!
All are simple, using local db, no AD or LDAP yet…
Actually, it was when testing to use LDAP/AD as per this post that I noticed, and checked all servers…
Sitting at the console again after a lengthy support session…
May 14 17:40:01 shzg-nethserver systemd: Started Session 6001 of user root.
May 14 17:40:01 shzg-nethserver systemd: Created slice User Slice of apache.
May 14 17:40:01 shzg-nethserver systemd: Started Session 6002 of user apache.
May 14 17:40:19 shzg-nethserver systemd: Removed slice User Slice of apache.
May 14 17:40:20 shzg-nethserver server: 17:40:20.142 [http-bio-8080-exec-35] INFO o.a.g.environment.LocalEnvironment - GUACAMOLE_HOME is “/usr/share/tomcat/.guacamole”.
May 14 17:40:21 shzg-nethserver guacd[24144]: Creating new client for protocol “rdp”
May 14 17:40:21 shzg-nethserver guacd: guacd[24144]: INFO:#011Creating new client for protocol “rdp”
May 14 17:40:21 shzg-nethserver guacd[24144]: Connection ID is “$452123b2-b570-4af0-9038-cf0685fac86a”
May 14 17:40:21 shzg-nethserver guacd: guacd[24144]: INFO:#011Connection ID is “$452123b2-b570-4af0-9038-cf0685fac86a”
May 14 17:40:26 shzg-nethserver guacd[6054]: Support for protocol “rdp” is not installed
May 14 17:40:26 shzg-nethserver guacd: guacd[6054]: WARNING:#011Support for protocol “rdp” is not installed
May 14 17:40:26 shzg-nethserver guacd[24144]: Connection “$452123b2-b570-4af0-9038-cf0685fac86a” removed.
May 14 17:40:26 shzg-nethserver guacd: guacd[24144]: INFO:#011Connection “$452123b2-b570-4af0-9038-cf0685fac86a” removed.
May 14 17:40:35 shzg-nethserver server: 17:40:35.394 [http-bio-8080-exec-19] ERROR o.a.g.w.GuacamoleWebSocketTunnelEndpoint - Creation of WebSocket tunnel to guacd failed: Connection to guacd timed out.
It seems that RDP isn’t installed?
Note, the above log messages are not from my home server (updated to 7.8 this morning), this server is still on 7.7.1908.
RDP directly to the PC/Server in question all work as expected. Just Guacamole has issues.
My Windows at home wanted an update first…
→ When you need it, it wants to update.
After Windows updating and reboot, Guacamole at home works…
I’m anyway going to update that server to 7.8 tonight, and will check that Guacamole is up to date…
But It’ll be shortly after midnight…
I’ll post the results here.
The special thing about that server: It’s part of a Hotels IT. And the whole IT “moved out”.
IP Range, Firewall are the same, only the Hotel accesses it per VPN / RDP. And Guacamole is a Failover in case of RDP / PC issues…
Sometimes, when wotking on 6 consoles with as much NethServers, my fingers are faster than my brain when it comes to copy & paste…
With Proxmox backups & snapshots, at least I’m on the safe side…
Removed freerdp1.2, rebooted.
[root@shzg-nethserver ~]# tail /var/log/messages
May 14 23:41:30 shzg-nethserver guacd: guacd[1032]: INFO:#011Connection “$e47a2967-fcd1-4c48-ac5d-fe855c48f727” removed.
May 14 23:41:45 shzg-nethserver server: 23:41:45.417 [http-bio-8080-exec-16] ERROR o.a.g.w.GuacamoleWebSocketTunnelEndpoint - Creation of WebSocket tunnel to guacd failed: Connection to guacd timed out.
May 14 23:42:16 shzg-nethserver sshd[4763]: error: PAM: Authentication failure for root from 192.168.114.1
May 14 23:42:21 shzg-nethserver sshd[4763]: Accepted keyboard-interactive/pam for root from 192.168.114.1 port 56229 ssh2
Guacamole daemon works in freerdp library v1 but In centos 7, yum installation come with v2.0.0, this breaks RDP functionality.
Fix it by removing v2 and installing v1.
restart service
