Tested with Alma 9 on Proxmox and Virtualbox.
Grafana and Prometheus work on cluster leader only, installing/configuring on a worker node didn’t work.
Both Grafana and Prometheus had following error on worker nodes:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/nethserver/logcli.env'
This file exists only on the leader node.
Grafana
Grafana installs on worker nodes but configure-module fails, it just works on the leader.
No containers were started.
Grafana worker node /var/log/messages
May 22 17:29:04 alma2 systemd[1281]: Starting Grafana server...
May 22 17:29:05 alma2 runagent[1666]: Traceback (most recent call last):
May 22 17:29:05 alma2 runagent[1666]: File "/home/grafana1/.config/bin/provision", line 32, in <module>
May 22 17:29:05 alma2 runagent[1666]: logcli = agent.read_envfile("/etc/nethserver/logcli.env")
May 22 17:29:05 alma2 runagent[1666]: File "/usr/local/agent/pypkg/agent/__init__.py", line 89, in read_envfile
May 22 17:29:05 alma2 runagent[1666]: fo = open(file_path, 'r')
May 22 17:29:05 alma2 runagent[1666]: FileNotFoundError: [Errno 2] No such file or directory: '/etc/nethserver/logcli.env'
May 22 17:29:05 alma2 systemd[1281]: grafana.service: Control process exited, code=exited, status=1/FAILURE
May 22 17:29:05 alma2 systemd[1281]: grafana.service: Failed with result 'exit-code'.
May 22 17:29:05 alma2 systemd[1281]: Failed to start Grafana server.
May 22 17:29:06 alma2 systemd[1281]: grafana.service: Scheduled restart job, restart counter is at 4.
May 22 17:29:06 alma2 systemd[1281]: Stopped Grafana server.
May 22 17:29:06 alma2 systemd[1281]: Starting Grafana server...
May 22 17:29:06 alma2 runagent[1675]: Traceback (most recent call last):
May 22 17:29:06 alma2 runagent[1675]: File "/home/grafana1/.config/bin/provision", line 32, in <module>
May 22 17:29:06 alma2 runagent[1675]: logcli = agent.read_envfile("/etc/nethserver/logcli.env")
May 22 17:29:06 alma2 runagent[1675]: File "/usr/local/agent/pypkg/agent/__init__.py", line 89, in read_envfile
May 22 17:29:06 alma2 runagent[1675]: fo = open(file_path, 'r')
May 22 17:29:06 alma2 runagent[1675]: FileNotFoundError: [Errno 2] No such file or directory: '/etc/nethserver/logcli.env'
May 22 17:29:06 alma2 systemd[1281]: grafana.service: Control process exited, code=exited, status=1/FAILURE
May 22 17:29:07 alma2 systemd[1281]: grafana.service: Failed with result 'exit-code'.
May 22 17:29:07 alma2 systemd[1281]: Failed to start Grafana server.
May 22 17:29:07 alma2 systemd[1281]: grafana.service: Scheduled restart job, restart counter is at 5.
May 22 17:29:07 alma2 systemd[1281]: Stopped Grafana server.
May 22 17:29:07 alma2 systemd[1281]: grafana.service: Start request repeated too quickly.
configure-module failed, log from UI:
"context": {
"action": "configure-module",
"data": {
"host": "grafana.mrmarkuz.ddnss.eu",
"http2https": true,
"lets_encrypt": false
"extra": {
"description": "Processing...",
"eventId": "5aa01173-ab84-4234-ab2d-2ada0b2667f8",
"title": "Configure grafana2"
"id": "af151d12-da28-4e81-a6e8-af8933fdc5f4",
"parent": "",
"queue": "module/grafana2/tasks",
"timestamp": "2023-05-22T17:36:13.253892893Z",
"user": "admin"
"status": "aborted",
"progress": 50,
"subTasks": [
"context": {
"action": "set-route",
"data": {
"http2https": true,
"instance": "grafana2",
"lets_encrypt": false,
"url": "http://127.0.0.1:20009"
"extra": {},
"id": "64acb3b4-ac62-4c28-9820-bf8fd56b09f3",
"parent": "af151d12-da28-4e81-a6e8-af8933fdc5f4",
"queue": "module/traefik2/tasks",
"timestamp": "2023-05-22T17:36:13.78511532Z",
"user": "module/grafana2"
"status": "completed",
"progress": 100,
"subTasks": [],
"result": {
"error": "",
"exit_code": 0,
"file": "task/module/traefik2/64acb3b4-ac62-4c28-9820-bf8fd56b09f3",
"output": ""
"validated": true,
"result": {
"error": "Job for grafana.service failed because the control process exited with error code.\nSee \"systemctl --user status grafana.service\" and \"journalctl --user -xeu grafana.service\" for details.\n",
"exit_code": 1,
"file": "task/module/grafana2/af151d12-da28-4e81-a6e8-af8933fdc5f4",
"output": ""
Prometheus
Prometheus installation fails on worker nodes.
UI log:
"context": {
"action": "add-module",
"data": {
"image": "ghcr.io/nethserver/prometheus:1.0.0",
"node": 2
"extra": {
"completion": {
"extraTextParams": [
"node"
"i18nString": "software_center.instance_installed_on_node",
"outputTextParams": [
"module_id"
"description": "Installing on Node 2",
"eventId": "9fb9b467-b0c3-4fcf-934e-2ebd2fab5430",
"node": "Node 2",
"title": "Install Prometheus"
"id": "f4970be3-839a-4f6f-a041-181db02b3cad",
"parent": "",
"queue": "cluster/tasks",
"timestamp": "2023-05-22T17:45:22.232176793Z",
"user": "admin"
"progress": 33,
"subTasks": [
"context": {
"data": {
"environment": {
"IMAGE_DIGEST": "sha256:e4c50fceb5c7c3170a25ea1af47e1232ad8b7e77b0e24672b4fff219327e59df",
"IMAGE_ID": "e28418b111cf330277d3dcfb29b9a9cc167bb370e8e3464e1ff4fb6562aeda05",
"IMAGE_REOPODIGEST": "ghcr.io/nethserver/prometheus@sha256:e4c50fceb5c7c3170a25ea1af47e1232ad8b7e77b0e24672b4fff219327e59df",
"IMAGE_URL": "ghcr.io/nethserver/prometheus:1.0.0",
"MODULE_ID": "prometheus1",
"MODULE_UUID": "b4057f5d-82c2-48d9-b39d-8a9770f0f449",
"NODE_ID": "2",
"TCP_PORT": "20011",
"TCP_PORTS": "20011"
"is_rootfull": false,
"module_id": "prometheus1"
"extra": {},
"id": "1e464de0-2041-428f-b9e7-953807ad141d",
"parent": "f4970be3-839a-4f6f-a041-181db02b3cad"
"progress": 100,
"subTasks": [],
"result": {
"error": "<7>useradd -m -k /etc/nethserver/skel -s /bin/bash prometheus1\n<7>extract-image ghcr.io/nethserver/prometheus:1.0.0\nTrying to pull ghcr.io/nethserver/prometheus:1.0.0...\nGetting image source signatures\nCopying blob sha256:7c29cac7af4b7e18ee9c8cb18f6c0534c49728b0f02aecc110c2189120d5eaaf\nCopying config sha256:e28418b111cf330277d3dcfb29b9a9cc167bb370e8e3464e1ff4fb6562aeda05\nWriting manifest to image destination\nStoring signatures\nExtracting container filesystem imageroot to /home/prometheus1/.config\nTotal bytes read: 7987200 (7.7MiB, 89MiB/s)\nimageroot/actions/\nimageroot/actions/create-module/\nimageroot/actions/create-module/20configure\nimageroot/actions/create-module/80start_services\nimageroot/actions/create-module/validate-input.json\nimageroot/actions/destroy-module/\nimageroot/actions/destroy-module/20destroy\nimageroot/actions/get-configuration/\nimageroot/actions/get-configuration/20read\nimageroot/actions/get-configuration/validate-output.json\nimageroot/bin/\nimageroot/bin/reload_configuration\nimageroot/bin/validation.json\nimageroot/etc/\nimageroot/etc/state-include.conf\nimageroot/events/\nimageroot/events/service-prometheus-metrics-updated/\nimageroot/events/service-prometheus-metrics-updated/10handler\nimageroot/systemd/\nimageroot/systemd/user/\nimageroot/systemd/user/prometheus.service\nchanged ownership of './state/environment' from root:root to prometheus1:prometheus1\nchanged ownership of './state/agent.env' from root:root to prometheus1:prometheus1\nchanged ownership of './systemd/user/prometheus.service' from root:root to prometheus1:prometheus1\nchanged ownership of './.imageroot.lst' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/create-module/20configure' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/create-module/80start_services' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/create-module/validate-input.json' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/create-module' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/destroy-module/20destroy' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/destroy-module' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/get-configuration/20read' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/get-configuration/validate-output.json' from root:root to prometheus1:prometheus1\nchanged ownership of './actions/get-configuration' from root:root to prometheus1:prometheus1\nchanged ownership of './actions' from root:root to prometheus1:prometheus1\nchanged ownership of './bin/reload_configuration' from root:root to prometheus1:prometheus1\nchanged ownership of './bin/validation.json' from root:root to prometheus1:prometheus1\nchanged ownership of './bin' from root:root to prometheus1:prometheus1\nchanged ownership of './etc/state-include.conf' from root:root to prometheus1:prometheus1\nchanged ownership of './etc' from root:root to prometheus1:prometheus1\nchanged ownership of './events/service-prometheus-metrics-updated/10handler' from root:root to prometheus1:prometheus1\nchanged ownership of './events/service-prometheus-metrics-updated' from root:root to prometheus1:prometheus1\nchanged ownership of './events' from root:root to prometheus1:prometheus1\n8110f86df277cb9ad22b879854df24efa4f65af9c7d9413ea51b2d0d1f00ea8e\n<7>loginctl enable-linger prometheus1\n",
"exit_code": 0,
"file": "task/node/2/1e464de0-2041-428f-b9e7-953807ad141d",
"output": {
"redis_sha256": "8f677f8ae005c949202e630474440ed05448d71299651e8b1e057fed27568f11"
"context": {
"action": "create-module",
"data": {
"images": [
"quay.io/prometheus/prometheus:v2.37.5"
"extra": {},
"id": "678a5ab9-4600-4bb6-b168-d651836ad8e9",
"progress": 77,
"subTasks": [
"context": {
"data": {
"http2https": false,
"instance": "prometheus1",
"path": "/589c23e0551e4481a4a3e80ddff21b56",
"url": "http://127.0.0.1:20011"
"extra": {},
"id": "529ba1d3-c1d5-4776-aa68-d13ef58cdfb1",
"parent": "678a5ab9-4600-4bb6-b168-d651836ad8e9",
"timestamp": "2023-05-22T17:45:44.382109352Z",
"user": "module/prometheus1"
"progress": 100,
"subTasks": [],
"result": {
"error": "",
"exit_code": 0,
"file": "task/module/traefik2/529ba1d3-c1d5-4776-aa68-d13ef58cdfb1",
"output": ""
"result": {
"error": "Add to module/prometheus1 environment PROMETHEUS_IMAGE=quay.io/prometheus/prometheus:v2.37.5\n<7>dump_env() is deprecated and implemented as a no-op\n<7>podman-pull-missing quay.io/prometheus/prometheus:v2.37.5\nTrying to pull quay.io/prometheus/prometheus:v2.37.5...\nGetting image source signatures\nCopying blob sha256:a364fdffa75b874796f397b75df22b943243de461006ddc5f6ed693af248c0cc\nCopying blob sha256:5c12815fee558b157dee7f7509dedbaba0a8379098858a65ec869e1f1526ea0c\nCopying blob sha256:22b70bddd3acadc892fca4c2af4260629bfda5dfd11ebc106a93ce24e752b5ed\nCopying blob sha256:ea71be1a17871f09737ccfb04116b09e7c85c921d91f310f544741d1907a92bd\nCopying blob sha256:f91bda4f4397a941b6706ca8c6a526fe80f187039bb05e2983eab8acb712e347\nCopying blob sha256:2596b6b1b5e8d84f84fc6adea2114aa358afaba0cb55a22bd7739c837f2566f9\nCopying blob sha256:5c3550bf7ce22ef28073d72f9e91f05ae3d10aa4ad42c48b42a750cce5f5d247\nCopying blob sha256:9e7f059b5bedeb9d64749f8176d28c96ca5b80cc8654a9b4bcae9ca3490d2d52\nCopying blob sha256:10b9a1426ff25cfb9391c4eef2705dc9ee7a0bedea500ed4153b2b3807cf3795\nCopying blob sha256:22a71175390db83d1f984b08620ef56d8a23e0df562c22245b510040f4428223\nCopying blob sha256:9a2560986b70c9d1f975e7f9bc1dfefa444918503db1c7c74dac074379745dd7\nCopying blob sha256:cca231f698f0adbb824708c35b6395cdb1b603716389a659bf80370453a75a1a\nCopying config sha256:cdc06c473c9b6f1ae04422ae8a901af087e35753439d7edad95706c2ba65134e\nWriting manifest to image destination\nStoring signatures\ncdc06c473c9b6f1ae04422ae8a901af087e35753439d7edad95706c2ba65134e\nTraceback (most recent call last):\n File \"/home/prometheus1/.config/actions/create-module/20configure\", line 53, in <module>\n logcli = agent.read_envfile(\"/etc/nethserver/logcli.env\")\n File \"/usr/local/agent/pypkg/agent/__init__.py\", line 89, in read_envfile\n fo = open(file_path, 'r')\nFileNotFoundError: [Errno 2] No such file or directory: '/etc/nethserver/logcli.env'\n",
"exit_code": 1,
"file": "task/module/prometheus1/678a5ab9-4600-4bb6-b168-d651836ad8e9",
"output": ""
"validated": true,
"result": {
"error": "<7>podman-pull-missing ghcr.io/nethserver/prometheus:1.0.0\nTrying to pull ghcr.io/nethserver/prometheus:1.0.0...\nGetting image source signatures\nCopying blob sha256:7c29cac7af4b7e18ee9c8cb18f6c0534c49728b0f02aecc110c2189120d5eaaf\nCopying config sha256:e28418b111cf330277d3dcfb29b9a9cc167bb370e8e3464e1ff4fb6562aeda05\nWriting manifest to image destination\nStoring signatures\ne28418b111cf330277d3dcfb29b9a9cc167bb370e8e3464e1ff4fb6562aeda05\n<7>extract-ui ghcr.io/nethserver/prometheus:1.0.0\nExtracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/prometheus1\nui/css/\nui/css/about~31ecd969.aaeac019.css\nui/css/app~748942c6.75af5757.css\nui/i18n/\nui/i18n/en/\nui/i18n/en/translation.json\nui/i18n/it/\nui/i18n/it/translation.json\nui/img/\nui/img/module_default_logo.cce7147c.png\nui/index.html\nui/js/\nui/js/about~31ecd969.174fb5c7.js\nui/js/about~31ecd969.174fb5c7.js.map\nui/js/app~748942c6.36add9e5.js\nui/js/app~748942c6.36add9e5.js.map\nui/js/chunk-vendors~02576867.44c88c8d.js\nui/js/chunk-vendors~02576867.44c88c8d.js.map\nui/js/chunk-vendors~0605657e.7f254d6a.js\nui/js/chunk-vendors~0605657e.7f254d6a.js.map\nui/js/chunk-vendors~0f485567.2b4008a3.js\nui/js/chunk-vendors~0f485567.2b4008a3.js.map\nui/js/chunk-vendors~17faf02d.7f68aab6.js\nui/js/chunk-vendors~17faf02d.7f68aab6.js.map\nui/js/chunk-vendors~1d97ff09.290bda9d.js\nui/js/chunk-vendors~1d97ff09.290bda9d.js.map\nui/js/chunk-vendors~2a42e354.0df57e14.js\nui/js/chunk-vendors~2a42e354.0df57e14.js.map\nui/js/chunk-vendors~2aa62147.38204dba.js\nui/js/chunk-vendors~2aa62147.38204dba.js.map\nui/js/chunk-vendors~41d44f25.e7779fa1.js\nui/js/chunk-vendors~41d44f25.e7779fa1.js.map\nui/js/chunk-vendors~46852254.0b6d19c2.js\nui/js/chunk-vendors~46852254.0b6d19c2.js.map\nui/js/chunk-vendors~57473a66.f586d2ed.js\nui/js/chunk-vendors~57473a66.f586d2ed.js.map\nui/js/chunk-vendors~5bb1f863.3efba861.js\nui/js/chunk-vendors~5bb1f863.3efba861.js.map\nui/js/chunk-vendors~5eba3806.b8428291.js\nui/js/chunk-vendors~5eba3806.b8428291.js.map\nui/js/chunk-vendors~690b702c.fd888ae3.js\nui/js/chunk-vendors~690b702c.fd888ae3.js.map\nui/js/chunk-vendors~7274e1de.72bc2eab.js\nui/js/chunk-vendors~7274e1de.72bc2eab.js.map\nui/js/chunk-vendors~86f6b1bc.a87cb010.js\nui/js/chunk-vendors~86f6b1bc.a87cb010.js.map\nui/js/chunk-vendors~b5906859.deff14e4.js\nui/js/chunk-vendors~b5906859.deff14e4.js.map\nui/js/chunk-vendors~bc21d4b3.da6ccf35.js\nui/js/chunk-vendors~bc21d4b3.da6ccf35.js.map\nui/js/chunk-vendors~c8728516.dd1ccc58.js\nui/js/chunk-vendors~c8728516.dd1ccc58.js.map\nui/js/chunk-vendors~d2305125.6a99a4ff.js\nui/js/chunk-vendors~d2305125.6a99a4ff.js.map\nui/js/chunk-vendors~d9886323.1a1a66f6.js\nui/js/chunk-vendors~d9886323.1a1a66f6.js.map\nui/js/chunk-vendors~db300d2f.ddb8641c.js\nui/js/chunk-vendors~db300d2f.ddb8641c.js.map\nui/js/chunk-vendors~ec8c427e.5c1734c3.js\nui/js/chunk-vendors~ec8c427e.5c1734c3.js.map\nui/js/chunk-vendors~fdc6512a.81c5c86c.js\nui/js/chunk-vendors~fdc6512a.81c5c86c.js.map\nui/js/lang-en-translation-json~9b60384d.182e4fbe.js\nui/js/lang-en-translation-json~9b60384d.182e4fbe.js.map\nui/js/lang-it-translation-json~e043826f.3fae064e.js\nui/js/lang-it-translation-json~e043826f.3fae064e.js.map\nui/metadata.json\nui/shortcuts.json\n619e08db58e8f3259403d0b58f89169dcfc205a4a9b330f9eb1998a75a860cc6\nAssertion failed\n File \"/var/lib/nethserver/cluster/actions/add-module/50update\", line 202, in <module>\n agent.assert_exp(create_module_result['exit_code'] == 0) # Ensure create-module is successful\n",
"exit_code": 2,
"file": "task/cluster/f4970be3-839a-4f6f-a041-181db02b3cad",
"output": ""
/var/log/messages:
May 22 18:24:29 alma2 prometheus2[5451]: Traceback (most recent call last):
May 22 18:24:29 alma2 prometheus2[5451]: File "/home/prometheus2/.config/actions/create-module/20configure", line 53, in <module>
May 22 18:24:29 alma2 prometheus2[5451]: logcli = agent.read_envfile("/etc/nethserver/logcli.env")
May 22 18:24:29 alma2 prometheus2[5451]: File "/usr/local/agent/pypkg/agent/__init__.py", line 89, in read_envfile
May 22 18:24:29 alma2 prometheus2[5451]: fo = open(file_path, 'r')
May 22 18:24:29 alma2 prometheus2[5451]: FileNotFoundError: [Errno 2] No such file or directory: '/etc/nethserver/logcli.env'
May 22 18:24:29 alma2 prometheus2[5451]: task/module/prometheus2/b1f598fb-2101-481e-9283-aeca9fb17c68: action "create-module" status is "aborted" (1) at step 20configure
