could we add go access for analytics of websites into Nethserver.
WE managed to add it inside CWP(https://control-webpanel.com) and considering cwp is a multi tenant system, it works great. so it should be possible to integrate it with nethserver.
is that just the way to isntall it, and it works with all the domains and websites hosted on netherver?
i guess there must be some more tinkering to do.
if you want something like a CLI, it is done, but you can generate html page, or json output that you can use later in your web page, you can export to a database to generate report later, it is really powerful
I found that there are problems with the stats generated since 1 July 2023, all owners of the logs under (e.g. /home//cwp_stat/<daily/monthly/weekly>/*) are root, since 2 July 2023, and the stats generation on 1 July 2023 is skipped. Also, all of my CWP servers have the same problems.
