Ive managed to get GLPI/Fusion Inventory/Nethserver AD and Flyve MDM working together here are the steps – Please note the first part is from my notes which might be out of date ill check and update as necessary also while not yet tested this should work on raspberry pi
Step 1.
In nethserver cockpit in webserver create a virtual host select php 7.3
Step 2.
Install Mariadb105 along with some additional prerequisites
yum install -y php-xmlrpc rh-php73 rh-mariadb105 mariadb-server glpi php-pecl-apcu php-pecl-zendopcache xmlrpc unzip git composer && sudo systemctl start mariadb.service && sudo mysql_secure_installation
Then create the user and database with
mysql105 -u root
CREATE USER 'glpi'@'127.0.0.1:3313' IDENTIFIED BY 'yourstrongpassdontuse$';
GRANT USAGE ON *.* TO 'glpi'@'127.0.0.1:3313' IDENTIFIED BY 'yourstrongpassdontuse$' REQUIRE NONE WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0;
CREATE DATABASE IF NOT EXISTS glpi;GRANT ALL PRIVILEGES ON glpi.* TO 'glpi'@'127.0.0.1:3313';
FLUSH PRIVILEGES;
quit
Step 3.
Download GLPI
cd /var/lib/nethserver/vhost/virtualhostrootdirectory
wget https://github.com/glpi-project/glpi/releases/download/9.5.5/glpi-9.5.5.tgz
tar -xvzf glpi-9.5.5.tgz
or if you want it to be accessable by just the virtualhost name add --strip 1 to the end of the command
tar -xvzf glpi-9.5.5.tgz --strip 1
cd ./glpi
find ./* -type d -exec chmod 755 {} + && find ./* -type f -exec chmod 644 {} +
chown apache:apache -R ./*
a2enmod rewrite
a2enmod proxy_fcgi setenvif
systemctl restart httpd
Step 4.
Open a webbrowser and go to https://virtualhost/glpi
a. Select your language
b. Agree to the terms
c. Choose Install
d. for the time being ignore the dependencies and continue
e. enter your database details as follows
SQL Server (MariaDB or MySQL)=127.0.0.1:3313
SQL User=glpi
SQL Password=yourstrongpassdontuse$
and ‘keep on going’
f. Select glpi database and continue and wait for Step 3 to display OK - database was initialized and click ‘keep on going’
g. Decide if you want to Send “usage statistics” and click ‘continue’
h. click ‘continue’ in step 5 and ‘use GLPI’ in step 6
*** note you might get an error like Invalid cookie data Empty login or password just click login again and the passwords to login (which must be changed from default) are as follows ***
- glpi / glpi (super-admin)
- tech / tech
- postonly / postonly (only for helpdesk)
- normal / normal
Dont forget to run rm ./install/install.php to remove install directory
also see here for the official docs from glpi 1 and here for the flyvemdm docs 1
Step 5.
To install flyve mdm
Cd to glpi virtual host root document folder
Install the following
yum install -y unzip git composer mosquitto mosquitto-clients mosquitto-dev
Then to save time later
cd ~
mosquitto -v
wget http://mosquitto.org/files/source/<output from previous cmd ie mosquitto-1.6.9.tar.gz>
sudo composer self-update --1 to avoid issues with later versions of composer*
cd ./glpi/plugins
git clone https://github.com/fusioninventory/fusioninventory-for-glpi.git fusioninventory
git clone https://github.com/flyve-mdm/glpi-plugin.git flyvemdm
git clone https://github.com/KSATDesign/mosquitto-auth-plug.git
mv mosquitto-auth-plug /usr/lib/mosquitto-auth-plug
cd ./flyvemdm
composer install --no-dev
ignore any errors at this point
Open a webbrowser and go to https://virtualhost/glpi/front/plugin.php
1st click the folder icon on the right side of FusionInventory under actions install and enable
Then do the same for flyvemdm
Step 6
To compile mosquitto-auth-plug
cd /usr/lib/mosquitto-auth-plug
nano config.mk.in
change
MOSQUITTO_SRC =
OPENSSLDIR = /usr
to
MOSQUITTO_SRC = /were you downloaded the source from previous section
OPENSSLDIR = /default openssl directory ie /usr/lib/ssl
then save file as config.mk
then run
make
To get Mosquitto to use mod-auth-plugin
nano /etc/mosquitto/conf.d/flyvemdm.conf
allow_anonymous false
auth_plugin /usr/lib/mosquitto-auth-plug/auth-plug.so
auth_opt_backends mysql
auth_opt_host localhost
auth_opt_port 3306
auth_opt_user glpi
auth_opt_dbname glpidb
auth_opt_pass yourstrongpassdontuse$
auth_opt_userquery SELECT password FROM glpi_plugin_flyvemdm_mqttusers WHERE user='%s' AND enabled='1'
auth_opt_aclquery SELECT topic FROM glpi_plugin_flyvemdm_mqttacls a LEFT JOIN glpi_plugin_flyvemdm_mqttusers u ON (a.plugin_flyvemdm_mqttusers_id = u.id) WHERE u.user='%s' AND u.enabled='1' AND (a.access_level & %d)
auth_opt_cacheseconds 300
listener 8883
cafile /etc/mosquitto/certs/cachain.pem
certfile /etc/mosquitto/certs/cachain.pem
keyfile /etc/mosquitto/certs/private-key.key
tls_version tlsv1.2
ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-RC4-SHA:AES128:AES256:HIGH:!RC4:!aNULL:!eNULL:!EXPORT:!DES:!3DES:!MD5:!PSK
Step 7.
We need to setup a script for moving certs and rehassing them and setup a Cron Job
The Script
cat > /etc/Jobs/certmove.sh <<EOF
#!/usr/bin/bash
sudo cp /etc/letsencrypt/live/yourdomain.tld/fullchain.pem /etc/mosquitto/certs/cachain.pem
sudo cp /etc/letsencrypt/live/yourdomain.tld/privkey.pem /etc/mosquitto/certs/private-key.key
sudo chmod 600 /etc/mosquitto/certs/private-key.key
sudo chown mosquitto:root /etc/mosquitto/certs/private-key.key
sudo c_rehash /etc/mosquitto/certs
sudo systemctl restart mosquitto
echo "done"
EOF
create the Cron job
nano /etc/crontab
15 3 * * * certbot renew --noninteractive --post-hook "/etc/Jobs/certmove.sh"
* * * * * /usr/bin/php7.3 /var/lib/nethserver/vhost/virtualhostrootdirectory/glpi/front/cron.php &>/dev/null # add this while were there
save and
systemctl reload cron # ill put the steps later for using crontab manager module
Step 8
As I’m using Letsencrypt for the cert i you need to copy the ad cert to the samba container to use ldaps to do that in a terminal add the following
cat <<EOF >>/etc/e-smith/events/certificate-update/S80push2ad
cp -f -p /etc/pki/tls/certs/localhost.crt /var/lib/machines/nsdc/var/lib/samba/private/tls/cert.pem
cp -f -p /etc/pki/tls/private/localhost.key /var/lib/machines/nsdc/var/lib/samba/private/tls/key.pem
chmod 600 /var/lib/machines/nsdc/var/lib/samba/private/tls/key.pem
chmod 644 /var/lib/machines/nsdc/var/lib/samba/private/tls/cert.pem
systemctl -M nsdc restart samba
EOF
To Setup LDAP(Nethserver AD) Under the glpi webinterface go to Setup > Authentication > LDAP directories and fill out the following:
------------------------------------------------LDAP Server Connection----------------------------------------------------
Default server=Servername-(or fqdn either works i believe it’s more of a descriptive name)
Active=Yes
Server=ldaps://ad.yourdomain.tld
Port=636
Connection Filter=(&(objectClass=user)(objectCategory=person)(!(userAccountControl:1.2.840.113556.1.4.803:=2)))
BaseDN=dc=ad,dc=yourdomain,dc=com,dc=au
RootDN(for non-anonymous binds)=a-user-in-the-domain-admin-group@AD.YOURDOMAIN.COM.AU
Password (for non-anonymous binds)=password for a-user-in-the-domain-admin-group
Login Field=samaccountname
Synchronization field=objectguid
---------------------------Binding to the LDAP directory (at least for anyone using Nethserver as ad)---------
Surname=sn
First name=givenname
Email=mail
Phone=telephonenumber
Mobile phone=mobile
Picture=thumbnailphoto
Location=%{streetaddress},%{postalcode},%{st},%{co}
--------------------Belonging to groups--------------
Search type=Users and Groups
User attribute containing its groups=memberof
Filter to search in groups=(objectClass=user)
--------------------------------------------Advanced information---------------------------------------------------------
LDAP directory time zone=yourGMT Offset if unsure check here *Note if you get an error about mysql cant access timezone see GLPI 9.4.6 to 9.5.1 MYSQL time zone access / English support / Forum GLPI-Project
Domain name used by inventory tool for link the user=ad.yourdomain.com.au
then go to Administration > Users
click on [LDAP Directory Link]
Then Click on [Import new users]
and on [expert mode]
and [search]
then do the same for groups
Step 9.
we now need to Install deeplinks (some things still a WIP)
cd /var/lib/nethserver/vhost/virtualhostrootdirectory/
git clone https://github.com/flyve-mdm/deeplink.git
cd deeplink/site
nano config.example.js
edit it to look like
window.appConfig = {
defaultLocation: "https://your glpi virtualhost/",
bugsnagApiKey: "optional",
deeplinkBase: "flyve://register?data=${data}",
androidDefaultLink: "https://f-droid.org/repo/org.flyve.mdm.agent.mqtt_3238.apk",
iosDefaultLink: "https://itunes.apple.com/us/app/flyve-mdm-inventory-agent" # not sure the location of the apple ipa so this won't work
save as config.js
Step 10
Setup the service startup script
nano /var/lib/nethserver/vhost/virtualhost/glpi/plugins/flyvemdm/scripts/flyvemdm.example.service
edit to look like this
Description=Flyve Mobile Device Management for GLPI
Wants=network.target
ConditionPathExists=/var/lib/nethserver/vhost/virtualhost/glpi/plugins/flyvemdm/scripts/mqtt.php
[Service]
Type=simple
User=httpd
Group=httpd
ExecStart=/var/lib/nethserver/vhost/virtualhost/glpi/plugins/flyvemdm/scripts/loop-run.sh
Restart=on-failure
SyslogIdentifier=flyvemdm
[Install]
WantedBy=multi-user.target
save as flyvemdm.service
systemctl daemon-reload
systemctl start flyvemdm.service
systemctl enable flyvemdm.service
Step 11
Enable email notifications by going to https://virtualhost/glpi/front/setup.notification.php
and enable the following
Enable followup => Yes
Enable followups via email => Yes
Enable followups from browser => Yes
then go to https://virtualhost/glpi/front/notificationmailingsetting.form.php
and fillout you mail server details
then go to https://virtualhost/glpi/front/crontask.form.php?id=22
In queuednotification settings
change Run Mode => CLI
Step 12
Setup API
go to https://virtualhost/glpi/front/config.form.php and go to api
Set the Following
URL of the API = https://virtualhost/apirest.php
Enable Rest API => Yes
Enable login with credentials => Yes
Enable login with external token => Yes
and create an api client
leave all blank except name
Name => a name of your choice
IPv4 Address Range=> your start and end iprange
Enable and save
Then go through the wizard (most things have been configured just need to Allow upload of APK and UPK files and follow the steps about disabling computers and inventory by name)
