Hello Guys, I have a custom CRM solution that i would to synchronize data between Nethserver AD, CRM and Zammad, for different case scenarios.
I am going to be using https://n8n.io/ an Opensource self hosted Zapier Alternative to achieve this.
currently, i am able to fetch and update data into existing crm using N8N, and i am also able to use the builtin API to fetch and update data into Zammad.
I was wondering, how can i be able to get records from Nethserver AD/Ldap
Available options are query, Http request, json and many other forms.
who has an idea on this.
Regards
