Hello friends,
I have probably built the biggest accident to be assumed here.
I installed Cups and Savapage on my Nethserver DC and shortly after removed them from the system. In addition, I have thrown the components perl, poppler, ImageMagick and avahi tools from the system. with the result that now nothing works here. No DNS, no HTTP, no service, nothing works. I can access the server via SSH. But no longer via Cockpit. See picture. Who can help me to get the server running again without reinstallation?
Do you have any backup of your current status?
After this backup, iâd suggest yum reinstall nethserver-cockpit
for a full reinstallation at least of the cockpit with all bells and whistles.
AFAIK, the information about nethserver configuration is âstill thereâ, but i donât know which signal-event should be triggered.
After regain access to Cockpit, considider to reinstall all âwanted modulesâ of your installation.
I am no certain of the result of my suggestions, so before act (except backup) consider other options before do something.
Check that route gives you the server gateway.
Check that dig answer you as intended.
Check if pinging outside the subnet works.
Did you already used network-recovery ? I am not suggesting to do that right now, only asking if already done.
Post the output of ifconfig please.
Do you have a recent backup?
Am I wrong assuming that itâs a no gateway configuration?
IMVHO currently your NethServer is relying to a DNS server thatâs ânot workingâ (stopped, unreachable, misconfigured, IDK)
This is the output of a working installation without NSDC.
[root@crippled ~]# dig
; <<>> DiG 9.11.4-P2-RedHat-9.11.4-26.P2.el7_9.9 <<>>
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 58702
;; flags: qr rd ra; QUERY: 1, ANSWER: 13, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;. IN NS
;; ANSWER SECTION:
. 85866 IN NS m.root-servers.net.
. 85866 IN NS b.root-servers.net.
. 85866 IN NS c.root-servers.net.
. 85866 IN NS d.root-servers.net.
. 85866 IN NS e.root-servers.net.
. 85866 IN NS f.root-servers.net.
. 85866 IN NS g.root-servers.net.
. 85866 IN NS h.root-servers.net.
. 85866 IN NS a.root-servers.net.
. 85866 IN NS i.root-servers.net.
. 85866 IN NS j.root-servers.net.
. 85866 IN NS k.root-servers.net.
. 85866 IN NS l.root-servers.net.
;; Query time: 10 msec
;; SERVER: 127.0.0.1#53(127.0.0.1)
;; WHEN: Sat Feb 26 18:26:17 CET 2022
;; MSG SIZE rcvd: 239
[root@crippled ~]#
and it rely on dnsmasq, which respond in this way for status
systemctl status dnsmasq
â dnsmasq.service - DNS caching server.
Loaded: loaded (/usr/lib/systemd/system/dnsmasq.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2022-02-25 15:04:45 CET; 1 day 3h ago
Main PID: 971 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
ââ971 /usr/sbin/dnsmasq -k
Feb 25 15:04:45 crippled.notur.biz systemd[1]: Started DNS caching server..
Feb 25 15:04:46 crippled.notur.biz dnsmasq[971]: started, version 2.76 cachesize 4000
Feb 25 15:04:46 crippled.notur.biz dnsmasq[971]: compile time options: IPv6 GNU-getopt DBus no-i18n IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth nettlehash no-DNSSEC loop-detect inotify
Feb 25 15:04:46 crippled.notur.biz dnsmasq-tftp[971]: TFTP root is /var/lib/tftpboot
Feb 25 15:04:46 crippled.notur.biz dnsmasq[971]: using nameserver 8.8.8.8#53
Feb 25 15:04:46 crippled.notur.biz dnsmasq[971]: read /etc/hosts - 2 addresses
[root@crippled ~]#
So with systemctl status dnsmasq should tell you if your dnsserver works.
The command signal-event nethserver-dnsmasq-save should save the configuration from the NethServer DB and apply it to dnsmasq but still donât advise to use that yet.
You could look for the journal for finding⌠why dnsmasq wonât work. My installation is structurally different from yours⌠mind that.
So dnsmasq donât work.
Configuration should be into /etc/dnsmasq.conf, viewable via cat.
IDK where to find any âquit and dirtyâ dnsmasq configuration for having at least a resolver working.
# at NethServer official site: https://www.nethserver.org
# 10base
# Set the domain for dnsmasq. this is optional, but if it is set, it
# does the following things.
# 1) Allows DHCP hosts to have fully qualified domain names, as long
# as the domain part matches this setting.
# 2) Sets the "domain" DHCP option thereby potentially setting the
# domain of all systems configured by DHCP
# 3) Provides the domain part for "expand-hosts"
domain=xxx.xxx.de
# 20dns
# Never forward plain names (without a dot or domain part)
domain-needed
# Using private dns servers, forwarding requests
# Domain is automatically added to simple names in a hosts-file.
expand-hosts
cache-size=4000
# 25NameServers
# Don't read /etc/resolv.conf. Get upstream servers only from the
# command line or the dnsmasq configuration file.
no-resolv
# Specify IP address of upstream servers directly. Setting this flag
# does not suppress reading of /etc/resolv.conf, use "no-resolv" to do
# that.
server=192.168.154.254
# By default, dnsmasq will send queries to any of the upstream
# servers it knows about and tries to favour servers that are known
# to be up. Uncommenting this forces dnsmasq to try each query
# with each server strictly in the order they appear in
# /etc/resolv.conf
all-servers
# 30dhcp
# Enable the DHCP server. Addresses will be given out from the range
# <start-addr> to <end-addr> and from statically defined addresses
# given in dhcp-host options.
# See db configuration getprop dnsmasq DhcpStatus
dhcp-range=set:br0,192.168.154.50,192.168.154.100,255.255.255.0,3
domain=ad.xxx.de,192.168.154.50,192.168.154.100
dhcp-option=tag:br0,option:router,192.168.154.254
dhcp-option=tag:br0,option:dns-server,192.168.154.1
dhcp-option=tag:br0,option:ntp-server,192.168.154.5
dhcp-option=tag:br0,option:tftp-server,192.168.154.1
dhcp-lease-max=51
# Should be set when dnsmasq is definitely the only DHCP server on a
# network.
dhcp-authoritative
# Read dhcp reservations from dhcp-hostsfile.
# See dhcp-hosts option for more informations.
dhcp-hostsfile=/etc/dnsmasq-dhcp-hosts
# 35NetbiosNameServers
# disabled
# 40bind
except-interface=virbr0
# 50sssd -- the Samba Domain controller is
# the authoritative DNS for our realm/domain
server=/ad.xxx.de/192.168.154.5
# 55DomainRedirection
# 80tftp
enable-tftp
tftp-root=/var/lib/tftpboot
# Create Domain wildcard for remote hosts
[root@dc01 ~]# systemctl start httpd shorewall
Job for shorewall.service failed because the control process exited with error c ode. See âsystemctl status shorewall.serviceâ and âjournalctl -xeâ for details.
Job for httpd.service failed because the control process exited with error code. See âsystemctl status httpd.serviceâ and âjournalctl -xeâ for details.
[root@dc01 ~]# systemctl status httpd shorewall -l
â httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/httpd.service.d
ââfree_mutex.conf, quick_kill.conf
Active: failed (Result: exit-code) since Sat 2022-02-26 21:59:26 CET; 57s ago
Docs: man:httpd(8)
man:apachectl(8)
Process: 11447 ExecStart=/usr/sbin/httpd $OPTIONS -DFOREGROUND (code=exited, status=1/FAILURE)
Process: 11441 ExecStartPre=/bin/bash -c ipcs -s | awk â$3==âapacheâ { print $2 }â | xargs -r â ipcrm sem (code=exited, status=0/SUCCESS)
Main PID: 11447 (code=exited, status=1/FAILURE)
Feb 26 21:59:26 dc01.de systemd[1]: Starting The Apache HTTP ServerâŚ
Feb 26 21:59:26 dc01.de httpd[11447]: httpd: Syntax error on line 353 of /etc/httpd/conf/httpd.conf: Syntax error on line 14 of /etc/httpd/conf.d/zz_meshcentral.conf: Could not open configuration file /etc/httpd/conf.d/default-virtualhost.inc: No such file or directory
Feb 26 21:59:26 dc01.de systemd[1]: httpd.service: main process exited, code=exited, status=1/FAILURE
Feb 26 21:59:26 dc01.de systemd[1]: Failed to start The Apache HTTP Server.
Feb 26 21:59:26 dc01.de systemd[1]: Unit httpd.service entered failed state.
Feb 26 21:59:26 dc01.de systemd[1]: httpd.service failed.
â shorewall.service - Shorewall IPv4 firewall
Loaded: loaded (/usr/lib/systemd/system/shorewall.service; disabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/shorewall.service.d
âânethserver-firewall-base.conf
Process: 11442 ExecStart=/usr/sbin/shorewall $OPTIONS start $STARTOPTIONS (code=exited, status=6)
Main PID: 11442 (code=exited, status=6)
Feb 26 21:59:26 dc01.de systemd[1]: Starting Shorewall IPv4 firewallâŚ
Feb 26 21:59:26 dc01.de shorewall[11442]: ERROR: Shorewall startup is disabled. To enable startup, set STARTUP_ENABLED=Yes in /etc/shorewall/shorewall.conf
Feb 26 21:59:26 dc01.de systemd[1]: shorewall.service: main process exited, code=exited, status=6/NOTCONFIGURED
Feb 26 21:59:26 dc01.de systemd[1]: Failed to start Shorewall IPv4 firewall.
Feb 26 21:59:26 dc01.de systemd[1]: Unit shorewall.service entered failed state.
Feb 26 21:59:26 dc01.de systemd[1]: shorewall.service failed.
