Did you install NethServer 7.9.2009?
If so, there is no “Dashboard” anymore, you can still install it from Software Center.
The newer Interface is Cockpit, it’s available on Port 9090.
Did you use the nethserver-iso or installed it “on top” of CentOS?
Did you set somethings on the commandline (ssh) after installation? If so which setting did you make?
@mark_nl
Of course -
I have a Fujitsu D3433 Board with 16 GB Ram and a 120GB Samsung M.2-Sata SSD.
Also 2 10TB HDD (configured later on as raid 1) for data space.
The system should work as an archive with syncthing installed.
I’ve dowloaded the nethserver-iso and installed from that.
After the installation everything was ok, so I configured the raid (and synched).
The only settings i made was the absolutely needed - hostname and so on. No other/special settings.
The only package installed in the nethserver is SoGo (just beeing curious).
After finishing the installation I shutdown the system and moved it downstairs to the final place and powered it up - thats all.
Now I have the Dashboard-problem.
I can access the system via ssh and I believe the fastest solution will be to restart from scratch and download the iso again.
Is it possible/remcommended to install a pure centos and add the nethserver later?
