In this case you may try to disable the core before reinstall. It should work but it’s always good to have a backup/snapshot.
Disable modules depending on core
Disable core - if it does not work check the error message, you may need to disable more modules
Download core from upstream and install
Enable modules
Adjust permissions
On a fresh installed freepbx it worked like this:
fwconsole ma disable callrecording cdr featurecodeadmin sipsettings userman voicemail
fwconsole ma disable core
fwconsole ma downloadinstall core
fwconsole ma enable core
fwconsole ma enable callrecording cdr featurecodeadmin sipsettings userman voicemail
fwconsole chown
If this does not work uninstalling instead of disabling core would be a possibility but it drops database tables so please backup.
If you do it you’ll need a
signal-event nethserver-freepbx-update
to reconfigure PBX for Nethserver (LDAP users etc.).
I didn’t test that and don’t know if it’s possible to reimport the database afterwards but it’s worth a try in last instance.
