Dear community.
It’s probably stupid, but it is.
It is about FreePBX. I have running Nethserver v. 7-7.1908 and everything works fine. Once I installed and tested freepbx. I was not sure if I will continue to run FreePBX on this server and wanted to completely uninstall and remove. I used a manual from Need help to remove asterisk.
Now I want to have it back and the installation of FreePBX runs without errors but does not work. https://my-nethserver/freepbx -> “File not found”
I think that Asterisk is not completely installed, because for example /var/lib/asterisk/bin/ is missing…
How can I restore all Asterisk packages and get FreePBX running again.
*** Installing FreePBX
Tue Mar 31 19:10:16 CEST 2020
Making sure asterisk user has bash as shell
usermod: no changes
Assuming you are Database Root
Checking if SELinux is enabled…Its not (good)!
Reading /etc/asterisk/asterisk.conf…Done
Checking if Asterisk is running and we can talk to it as the ‘asterisk’ user…Yes. Determined Asterisk version to be: 13.29.2
Preliminary checks done. Starting FreePBX Installation
Checking if this is a new install…Yes (No /etc/freepbx.conf file detected)
Database Root installation checking credentials and permissions…Connected!
Initializing FreePBX Settings
/etc/e-smith/events/nethserver-freepbx-update/S55nethserver-freepbx-conf-scl: line 39: /usr/sbin/fwconsole: No such file or directory
/etc/e-smith/events/nethserver-freepbx-update/S55nethserver-freepbx-conf-scl: line 40: /usr/sbin/fwconsole: No such file or directory
Tue Mar 31 20:51:37 CEST 2020
usermod: no changes
Empty asteriskcdrdb Database going to populate it
It seems you still have the asterisk db as only the asteriskcdrdb is populated.
Please delete both DBs:
mysql
drop database asterisk;
drop database asteriskcdrdb;
exit
This is how it looks when it works:
Checking if this is a new install...Yes (No /etc/freepbx.conf file detected)
Database Root installation checking credentials and permissions..Connected!
Empty asterisk Database going to populate it
Updating tables admin, ampusers, cronmanager, featurecodes, freepbx_log, freepbx_settings, globals, module_xml, modules, notifications, cron_jobs...Done
Changing AMPWEBROOT [/var/www/html] to match what was given at install time: /var/www/html/freepbx
Changing AMPMGRPASS [amp111] to match what was given at install time: cef06c6402ded3df51320c178596c0c4
Changing ASTMODDIR [/usr/lib/asterisk/modules] to match what was given at install time: /usr/lib64/asterisk/modules
