NethServer Version: NethServer 7.9.2009 (final)
Module: FreePBX
I keep playing around with VoIP and FreePBX a bit and when trying to install the User Control Panel and WebRTC modules FreePBX ends up with this error:
gcc-c ++ is not installed
Error (s) installing ucp:
Error running installation scripts
Reading a bit through the forum, I have found
and I have executed
yum install gcc-c++
But when installing it tells me to install these dependencies as well
> [root@server ~]# yum install gcc-c++ > Loaded plugins: changelog, fastestmirror, nethserver_events > Loading mirror speeds from cached hostfile > * ce-base: mirrors.prometeus.net > * ce-extras: mirrors.prometeus.net > * ce-sclo-rh: mirrors.prometeus.net > * ce-sclo-sclo: mirrors.prometeus.net > * ce-updates: mirrors.prometeus.net > * epel: mirror.nextlayer.at > * nethforge: ketrax.eu > * nethserver-base: ketrax.eu > * nethserver-updates: ketrax.eu > * remi-safe: remirepo.reloumirrors.net > Resolving Dependencies > --> Running transaction check > ---> Package gcc-c++.x86_64 0:4.8.5-44.el7 will be installed > --> Processing Dependency: libstdc++-devel = 4.8.5-44.el7 for package: gcc-c++-4 .8.5-44.el7.x86_64 > --> Processing Dependency: gcc = 4.8.5-44.el7 for package: gcc-c++-4.8.5-44.el7. x86_64 > --> Processing Dependency: libmpc.so.3()(64bit) for package: gcc-c++-4.8.5-44.el 7.x86_64 > --> Running transaction check > ---> Package gcc.x86_64 0:4.8.5-44.el7 will be installed > --> Processing Dependency: cpp = 4.8.5-44.el7 for package: gcc-4.8.5-44.el7.x86_ 64 > --> Processing Dependency: glibc-devel >= 2.2.90-12 for package: gcc-4.8.5-44.el 7.x86_64 > ---> Package libmpc.x86_64 0:1.0.1-3.el7 will be installed > ---> Package libstdc++-devel.x86_64 0:4.8.5-44.el7 will be installed > --> Running transaction check > ---> Package cpp.x86_64 0:4.8.5-44.el7 will be installed > ---> Package glibc-devel.x86_64 0:2.17-323.el7_9 will be installed > --> Processing Dependency: glibc-headers = 2.17-323.el7_9 for package: glibc-dev el-2.17-323.el7_9.x86_64 > --> Processing Dependency: glibc-headers for package: glibc-devel-2.17-323.el7_9 .x86_64 > --> Running transaction check > ---> Package glibc-headers.x86_64 0:2.17-323.el7_9 will be installed > --> Processing Dependency: kernel-headers >= 2.2.1 for package: glibc-headers-2. 17-323.el7_9.x86_64 > --> Processing Dependency: kernel-headers for package: glibc-headers-2.17-323.el 7_9.x86_64 > --> Running transaction check > ---> Package kernel-headers.x86_64 0:3.10.0-1160.15.2.el7 will be installed > --> Finished Dependency Resolution > > Dependencies Resolved > > ================================================================================ > Package Arch Version Repository Size > ================================================================================ > Installing: > gcc-c++ x86_64 4.8.5-44.el7 ce-base 7.2 M > Installing for dependencies: > cpp x86_64 4.8.5-44.el7 ce-base 5.9 M > gcc x86_64 4.8.5-44.el7 ce-base 16 M > glibc-devel x86_64 2.17-323.el7_9 ce-updates 1.1 M > glibc-headers x86_64 2.17-323.el7_9 ce-updates 691 k > kernel-headers x86_64 3.10.0-1160.15.2.el7 ce-updates 9.0 M > libmpc x86_64 1.0.1-3.el7 ce-base 51 k > libstdc++-devel x86_64 4.8.5-44.el7 ce-base 1.5 M > > Transaction Summary > ================================================================================ > Install 1 Package (+7 Dependent packages) > > Total download size: 42 M > Installed size: 84 M
Can I safely upgrade a server in production?
Thanks for your help!
