Forwarding domain name url to a specific machine
NethServer Version: 7.8
I am trying to figure out how to forward a specific URL, for example, somerandomname.ddns.net to a specific machine inside the network. How can I do that with Nethserver?
Thanks
I think I may have found the answer. I need to install the Reverse Proxy component, that is the only way, correct?
@tessierp
Reverse Proxy is the easiest way… :slight_smile:
Indeed, and it looks very easy to setup with NethServer. I need this for HomeAssistant since they don’t offer https. So I need to use a reverse proxy to have https from the outside to my nethserver box, have the ssl terminate and push the request internally to my home assistant instance.
@tessierp
Hi Patrick
I’m also using reverse proxy for the same purpose, but HomeAssistant I think needs more.
I can view stuff, but mostly can’t set anything.
I’m also using a Duck DNS name, that works perfectly but does not use my domain name.
But I made a DNS pointer on NethServer and on OPNsense, my firewall, and Duck DNS works in and outside of my home LAN correctly. I need this for their App.
Duck DNS is a plug in for HomeAssistant. Together with the NGINX SSL plug in, this works as expected!
Yeah I saw that plug in. I am using NO-IP right now but they charge you after 3 domains. So I will probably consider switching to Duck DNS instead.
I don’t think I’ll need to use that part for Home Assistant if I can have Nethserver handle the SSL termination and just pass in the traffic with plain http to home assistant. As long as I am convered on the outside I’m good with that.
Just tried it. Able to get to the login page and then, Home Assistant gives me this
I guess I’m missing something.
