Seems that after upgrading to NS 7.9, I cannot click “forward” on mail in webtop.
Even more weird, I have found at least one email that I CAN click forward - but most (if not all rest), I cannot.
Reply works properly.
I tested this from two completely different computers and networks.
ext-all.js:19 Uncaught Error: You're trying to decode an invalid JSON String:
at new Ext.Error (ext-all.js:19)
at Function.raise (ext-all.js:19)
at Object.Ext.raise (ext-all.js:19)
at Object.Ext.JSON.me.decode (ext-all.js:19)
at g.success (com.sonicle.webtop.core-private.js:1)
at Object.callback (ext-all.js:19)
at F.onComplete (ext-all.js:19)
at F.onStateChange (ext-all.js:19)
at XMLHttpRequest.t (ext-all.js:19)
It is chrome 86 (updating now - yes same with 87) on Win10x64.
Incognito, same thing (so not an extension).
Chromium based Edge, same thing.
Same even with… Tor (that is firefox based).
Also just found a couple of mail that clicking forward works fine (same recipient, not sure if related). Mail right right below those, no go.
No attachments or anything. Simple email.
if you tell me where is that
ah you mean export one of the email that cannot be forwarded
ok
sent
it is a simple mail nothing special about it
no they don’t have the same antivirus
There is nothing else in the console.
And the server is right on the same switch with the client (or one of the clients I tried).
And same mail does not “click” forward and same mail DOES “click” forward.
Failing network requests cannot be selective to same mail, all the time.
