Hi all,
Haven’t been here for a while and I’ve forgot how to login.
Tried the root/default password in the docs but it doesn’t work.
Installed the nethserver on KVM
Shame on me, please remind me how to do it.
Hi all,
Log in to what? The server manager is at https://your_ip:980, default username is root, password is whatever root password you set when you installed the system.
If you used the unattended install, the root password is Nethesis,1234
