Premise that they are the first experience with computer server side, I wanted to know how to make the first access to Sogo on Nethserver.
I 've installed and when I try to access my credentials to log on Nethserver not work.
Esisteno of default credentials?
Or do some operation via the terminal?
You must have an user account (the username and password will be used to login on SOGo Groupware) with email address created on NS: Management -> Users ; Management -> Email addresses.
SOGo Webmail access:
From NS WebUI: Status -> Dashboard -> Applications: url: SOGo Groupware
Thanks a lot for the answer . I was able to finally access to SOGo. Your advice to me were very helpful given my lack of knowledge. Now I will try to set it.
thanks again
