MadPatrick
(MadPatrick)
1
Hello
I’m getting the following error since the last update
How can i solve this?
I have certificate in NS8. Al my certifcates are in Nethsecurity
[1] Firing
Labels
alertname = certexp
cn = pdebrabander.nl
instance = 10.5.4.1:8082
job = providers
module_id = traefik1
node = 1
sans = pdebrabander.nl
serial = 428354233474222504373163160774557446768168
severity = critical
target_type = traefik
Annotations
description = The traefik1 expired certificate pdebrabander.nl (also for pdebrabander.nl) on Node 1 must be immediately renewed, or removed from the TLS certificates page.
summary = TLS certificate on Node 1 has expired since 272d 18h 56m 21s
mrmarkuz
(Markus Neuberger)
2
Please check the TLS certificates page and remove not needed certificates, see TLS certificates — NS8 documentation
I have the same problem here. But I’m seeing supposedly expired certificates for host names that haven’t existed on the server for quite some time.
mrmarkuz
(Markus Neuberger)
4
It’s not a problem, it’s a new feature.
You can just delete them.
I understand that, but they don’t exist. At least not among the HTTP routes.
mrmarkuz
(Markus Neuberger)
6
They can be deleted on the TLS certificates page, see TLS certificates — NS8 documentation
All right, I’ve found it.
