My brand new Manjaro KDE (Which is giving me a hard time to configure) and my Nexus 6P are currently connected to this Gateway (My entire network is using DHCP). I just restore my Gateway and the problem persist. I haven’t configured proxy setting on my PC and there is also other terminals browsing the Internet which souldn’t be allowed to (I’m using NTOPNG on the Gateway to see this)
# systemctl status shorewall.service -l
â—Ź shorewall.service - Shorewall IPv4 firewall
Loaded: loaded (/usr/lib/systemd/system/shorewall.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/shorewall.service.d
└─nethserver-firewall-base.conf
Active: active (exited) since Wed 2018-08-01 22:59:22 CDT; 3h 54min left
Process: 1136 ExecStart=/usr/sbin/shorewall $OPTIONS start $STARTOPTIONS (code=exited, status=0/SUCCESS)
Main PID: 1136 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/shorewall.service
Aug 01 22:59:21 heimdall.dcserver.local shorewall[1136]: 25 TC commands executed
Aug 01 22:59:21 heimdall.dcserver.local shorewall[1136]: All Done! Enjoy...
Aug 01 22:59:21 heimdall.dcserver.local shorewall[1136]: bye...
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: Preparing iptables-restore input...
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: Running /sbin/iptables-restore --wait 60...
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: IPv4 Forwarding Enabled
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: Processing /etc/shorewall/start ...
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: Processing /etc/shorewall/started ...
Aug 01 22:59:22 heimdall.dcserver.local shorewall[1136]: done.
Aug 01 22:59:22 heimdall.dcserver.local systemd[1]: Started Shorewall IPv4 firewall.
# systemctl status squid -l
â—Ź squid.service - Squid caching proxy
Loaded: loaded (/usr/lib/systemd/system/squid.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2018-08-01 22:59:18 CDT; 3h 50min left
Process: 1373 ExecStart=/usr/sbin/squid $SQUID_OPTS -f $SQUID_CONF (code=exited, status=0/SUCCESS)
Process: 1365 ExecStartPre=/usr/libexec/squid/cache_swap.sh (code=exited, status=0/SUCCESS)
Main PID: 1452 (squid)
CGroup: /system.slice/squid.service
├─1452 /usr/sbin/squid -f /etc/squid/squid.conf
├─1455 (squid-1) -f /etc/squid/squid.conf
├─1456 (ufdbgclient) -l /var/log/squid
├─1457 (ufdbgclient) -l /var/log/squid
├─1458 (ufdbgclient) -l /var/log/squid
├─1459 (ufdbgclient) -l /var/log/squid
├─1460 (ufdbgclient) -l /var/log/squid
├─1461 (logfile-daemon) /var/log/squid/access.log
├─1973 (ufdbgclient) -l /var/log/squid
├─1974 (ufdbgclient) -l /var/log/squid
├─1975 (ufdbgclient) -l /var/log/squid
├─1976 (ufdbgclient) -l /var/log/squid
└─1977 (ufdbgclient) -l /var/log/squid
Aug 01 22:59:17 heimdall.dcserver.local systemd[1]: Starting Squid caching proxy...
Aug 01 22:59:18 heimdall.dcserver.local squid[1373]: 2018/08/01 22:59:18| Warning: empty ACL: acl no_cache dstdomain "/etc/squid/acls/no_cache.acl"
Aug 01 22:59:18 heimdall.dcserver.local squid[1452]: Squid Parent: will start 1 kids
Aug 01 22:59:18 heimdall.dcserver.local squid[1452]: Squid Parent: (squid-1) process 1455 started
Aug 01 22:59:18 heimdall.dcserver.local systemd[1]: Started Squid caching proxy.
# systemctl status ufdb -l
â—Ź ufdb.service - LSB: ufdbguardd daemons from URLfilterDB
Loaded: loaded (/etc/rc.d/init.d/ufdb; bad; vendor preset: disabled)
Active: active (running) since Wed 2018-08-01 22:59:16 CDT; 3h 49min left
Docs: man:systemd-sysv-generator(8)
Process: 1137 ExecStart=/etc/rc.d/init.d/ufdb start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/ufdb.service
└─1208 /usr/sbin/ufdbguardd -U ufdb -c /etc/ufdbguard/ufdbGuard.conf
Aug 01 22:59:15 heimdall.dcserver.local systemd[1]: Starting LSB: ufdbguardd daemons from URLfilterDB...
Aug 01 22:59:16 heimdall.dcserver.local ufdb[1137]: Starting ufdbguardd daemon OK
Aug 01 22:59:16 heimdall.dcserver.local systemd[1]: Started LSB: ufdbguardd daemons from URLfilterDB.
