how can you make the one computer in the network reachable from the outside, but using an already used port?
My NS logs on to a dynDNS service and is more accessible from outside, I have the following ports free: 80; 443,980,9090 and some more SMTP, etc …
Now I would like to make another computer that is in the local network befeindet reachable from the outside, he should listen to the port 80.
Actually, I use a different port: 8080, which I simply forward internally in the firewall.
Now, however, should no longer be forwarded by port, but by name?
NS = 192.168.20.100 (A_external.domain.com)
Client = 192.168.20.111 (B_external.domain.com)
Both are to listen on the port 80.
Is it possible?
If so, how do you configure the firewall?
Thank you!
LG
Gerald
