Hello everybody. I have the following problem on my file server. My sharing works on a departmental basis, but each department has the “Recyle Bin” folder in the folder, but I noticed that when I delete any file it is no longer going to that folder anymore. I tried looking for some topics but couldn’t find any related.
the “Network Recyle Bin”-Option is enabled?
martin
Yes, the option is enabled.
Maybe some GNU/Linux or ACL permission problem.
Can you try creating a new test share with recycle bin enabled and check if it works there? (also helpful to compare permissions with the not working ones).
