whenever i receive fax reports , they are in Italian
how to receive English reports
It’s not well documented , try this commands:
config setprop hylafax Lang en_US
signal-event nethserver-hylafax-update
You can find more info here: http://docs.nethserver.org/projects/nethserver-devel/en/latest/hylafax.html
Hi @hany and @giacomo , according to hylafax dictionary :
less /var/spool/hylafax/bin/dictionary
if you do not specify Lang it will be English by default.
So @hany try
config setprop hylafax Lang ' '
IMHO it should be the default
You’re right, fixed in v7: config: change default lang to English · NethServer/nethserver-hylafax@727b405 · GitHub
do you mean that only in NS7 it will be corrected?
you’d correct it in 6.X branch too… people will use it for a quite long time, you can’t expect them to poke with CLI for such things
No, fixes will be backported when we close 7a2.
Usually, changes to default configuration should be integrated only when there is a new major version like 7 (or 6.8).
But I agree with you that this is should be consider a bug.
Can you please open a new issue, cherry-pick the commit and open a pull request?
Thank you!
I reinstalled fax server :
Lang=it_IT
is hard coded
Maybe we need the Menu for Languages in feature releases?
even with the webmail client roundcube , when the user login for the first time it’s all Italian
he has to guess where is the settings “in Italian” and then “languages” and changes it back to English
but don’t expect all users to be able to do that right a way
Oh @hany
please run
yum install nethserver-lang-en
or form
Administration => Software Center install English support.
No is not, it’s a prop and it’s inside the db.
Absolutely!
Roundcube will use the default language of you browser (see nethserver-roundcubemail/root/etc/e-smith/templates/etc/roundcubemail/config.inc.php/60USER_INTERFACE at master · NethServer/nethserver-roundcubemail · GitHub) , but you can also change it from Settings page.
