rmk
(Reggie Ho)
July 28, 2017, 5:02pm
1
NethServer Version: 7.3.1611
Module: fail2ban 0:0.9.6-3.el7
I had a problem with Server Error in LAPD… Install New Server and restore the Backup Configuration file… Everything else works, except fail2ban module refused to start.
Tried removing fail2ban , delete the fail2ban directory in /etc, reinstall, still not able to start the Fail2Ban Service… Appreciate help…
Thanks in advance…
stephdl
(Stéphane de Labrusse)
July 28, 2017, 5:17pm
2
see the fail2ban log in /var/log
probably a jail is missed
rmk
(Reggie Ho)
July 28, 2017, 5:23pm
3
the fail2ban log is empty…
stephdl
July 28, 2017, 5:25pm
4
try to start manually by the commandline and see what it occurs
systemctl start fail2ban
rmk
(Reggie Ho)
July 28, 2017, 5:29pm
5
This is what I see
fail2ban.service - Fail2Ban Service
Loaded: loaded (/usr/lib/systemd/system/fail2ban.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Fri 2017-07-28 10:27:22 PDT; 33s ago
Docs: man:fail2ban(1)
Process: 3590 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: fail2ban.service: control process …5
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: Failed to start Fail2Ban Service.
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: Unit fail2ban.service entered fail…
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: fail2ban.service failed.
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: fail2ban.service holdoff time over…
Jul 28 10:27:22 zzz.xxx.xxx systemd[1]: start request repeated too quickly…e
Jul 28 10:27:22 zzz.xxx.xxxt systemd[1]: Unit fail2ban.service entered fail…
Jul 28 10:27:22 zzz.xxx.xxxt systemd[1]: fail2ban.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
stephdl
July 28, 2017, 5:31pm
6
rpm -qa |grep -i fail2ban
rmk
(Reggie Ho)
July 28, 2017, 5:32pm
7
fail2ban-server-0.9.6-3.el7.noarch
nethserver-fail2ban-0.1.21-1.ns7.sdl.noarch
fail2ban-firewalld-0.9.6-3.el7.noarch
fail2ban-shorewall-0.9.6-3.el7.noarch
fail2ban-0.9.6-3.el7.noarch
fail2ban-sendmail-0.9.6-3.el7.noarch
rmk
(Reggie Ho)
July 28, 2017, 5:46pm
10
no go… I’d reboot server…
rmk
(Reggie Ho)
July 28, 2017, 5:48pm
11
Reboot server … still no Go…
rmk
(Reggie Ho)
July 28, 2017, 5:49pm
12
I tried uninstall and deleted the fail2ban folder, re-install,. and still no go
rmk
(Reggie Ho)
July 28, 2017, 6:05pm
13
I ran this fail2ban-client start
and got this error:::
ERROR No file(s) found for glob /var/log/sogo/sogo.log
ERROR Failed during configuration: Have not found any log file for sogo-auth jail
rmk
(Reggie Ho)
July 28, 2017, 6:09pm
14
Re-Install SoGO… and it’s running…
OMG… seems like I can’t remove SOGO if I want to keep fail2ban
stephdl
July 28, 2017, 6:38pm
15
You can also remove sogo and if needed
config delete sogod
signal-event nethserver-fail2ban-save
it makes me thing that I can protect this jail by looking if the log /var/log/sogo/sogo.log exists
rmk
(Reggie Ho)
July 28, 2017, 8:31pm
17
Thanks so much again for the help…much appreciate it .
