Fail2ban and webmail roundcube
NethServer Version: 7.5.1804 (final) + last update
Module: Email, Webmail, Fail2ban
Hi!
I use email+webmail(roundcube).
I installed fail2ban from NS-Software Center
And setup ‘Allow bans on the LAN’ in NS-Fail2ban
I try enter incorrect password to webmail roundcube
And it’s nothing, fal2ban not block IP address and not show status ‘Banned IP’.
I see /etc/fail2ban/jail.local config
[roundcube-auth]
enabled = true
port = 80,443
logpath = /var/log/roundcubemail/errors
maxretry = 3
but in /var/log/roundcubemail/errors file not entries fail authentification
i create custom template and change it to
[roundcube-auth]
enabled = true
port = 80,443
logpath = /var/log/roundcubemail/errors.log
maxretry = 3
and it works fine
please check and test it
it bug?
Sorry for my English…
yes it seems, thank for report it
Hi!
i think found new problem with fail2ban and roundecube!
my Lan scheme
[internet] — [NS7(gateway,proxy, ReverseProxy etc)] ---- [LAN]— PC1, PCn …----[NS7(emai,webmail, roundcube, fail2ban)]
my email+webmail+fail2ban server inside in LAN and for LAN users fail2ban work ok
i config reverseproxy for access external users to my server roundcube.
and fal2ban not block IP address external users and not show status ‘Banned IP’
i see
and see next entries, for example
[26-Sep-2018 20:08:15 +0500]: IMAP Error: Login failed for ib from 192.168.XXX.XXX(X-Forwarded-For: XXX.XXX.XXX.XXX). AUTHENTICATE PLAIN: Password: in /usr/share/roundcubemail/program/lib/Roundcube/rcube_imap.php on line 197 (POST /webmail/?_task=login?_task=login&_action=login)
i see ip address 192.168.XXX.XXX - its IP my NS7(gateway,proxy, ReverseProxy etc) internal LAN
and see X-Forwarded-For: XXX.XXX.XXX.XXX its real users external IP
i think fail2ban not matched if see X-Forwarded-For: XXX.XXX.XXX.XXX
if entries look like
[26-Sep-2018 18:52:26 +0500]: IMAP Error: Login failed for ib from 192.168.XXX.XXX. AUTHENTICATE PLAIN: Password: in /usr/share/roundcubemail/program/lib/Roundcube/rcube_imap.php on line 197 (POST /webmail/?_task=login?_task=login&_action=login)
without string X-Forwarded-For
it work and fail2ban work ok
Sorry my English…
I think the problem is in the file
/etc/file2ban/filter.d/roundcube-auth.conf
in the variable
failregex
should be added.
But how? i dont no.
would you mind to test this rpm :
yum install http://packages.nethserver.org/nethserver/7.5.1804/autobuild/x86_64/Packages/nethserver-fail2ban-1.0.6-1.2.pr40.g56775af.ns7.noarch.rpm
it only corrects the log path to the correct one, please test and report
we could not cover all corner cases done by custom customization, at least now. That’s said this is right for all web applications you have on your server (phpmyadmin, sogo, …)
you could make a filter.local
/etc/fail2ban/filter.d/roundcube-auth.local
copy all the regex and add one more…not tested you should adapt it
^\s*(\[\])?(%(__hostname)s\s*(roundcube:)?\s*(<[\w]+>)? IMAP Error)?: (FAILED login|Login failed) for .*? from * (X-Forwarded-For: <HOST>)(\. .* in .*?/rcube_imap\.php on line \d+ \(\S+ \S+\))?$
you have a tools for that Fail2ban — NethServer 7 Final
work fine, thank you!
not worked
i create file roundcube-auth.local
[INCLUDES]
before = common.conf
[Definition]
failregex = ^\s*(\[\])?(%(__hostname)s\s*(roundcube:)?\s*(<[\w]+>)? IMAP Error)?: (FAILED login|Login failed) for .*? from <HOST>(\. .* in .*?/rcube_imap\.php on line \d+ \(\S+ \S+\))?$
            ^\[\]:\s*(<[\w]+>)? Failed login for [\w\-\.\+]+(@[\w\-\.\+]+\.[a-zA-Z]{2,6})? from <HOST> in session \w+( \(error: \d\))?$
ignoreregex =
test it
fail2ban-regex /var/log/roundcubemail/errors.log /etc/fail2ban/filter.d/roundcube-auth.local
Running tests
Use   failregex filter file : roundcube-auth, basedir: /etc/fail2ban
Use         log file : /var/log/roundcubemail/errors.log
Use         encoding : UTF-8
Results
Failregex: 70 total
|-  #) [# of hits] regular expression
|   1) [70] ^\s*(\[\])?(\S+\s*(roundcube:)?\s*(<[\w]+>)? IMAP Error)?: (FAILED login|Login failed) for .*? from <HOST>(\. .* in .*?/rcube_imap\.php on line \d+ \(\S+ \S+\))?$
Ignoreregex: 0 total
Date template hits:
|- [# of hits] date format
|  [112] Day(?P<_sep>[-/])MON(?P=_sep)Year[ :]?24hour:Minute:Second(?:\.Microseconds)?(?: Zone offset)?
Lines: 112 lines, 0 ignored, 70 matched, 42 missed
[processed in 0.02 sec]
Missed line(s): too many to print.  Use --print-all-missed to print all 42 lines
‘X-Forwarded-For’ missed
[28-Sep-2018 11:29:58 +0500]: <bvdem97f> IMAP Error: Login failed for ib from 192.168.XX.XX(X-Forwarded-For: XXX.XXX.XXX.XXX). AUTHENTICATE PLAIN: Password: in /usr/share/roundcubemail/program/lib/Roundcube/rcube_imap.php on line 197 (POST /webmail/?_task=login?_task=login&_action=login)
may be i some thing wrong do?
you matched the regex 70 times :-?
add --print-all-matched to check what you matched
@stephdl already fixed the bug! :clap:
@xcod would you like to do the QA?
i tested it
work fine
no more questions
matched if like look
[28-Sep-2018 11:25:06 +0500]: <ta0bma91> IMAP Error: Login failed for ib from 192.168.XX.XX. AUTHENTICATE PLAIN: Password: in /usr/share/roundcubemail/program/lib/Roundcube/rcube_imap.php on line 197 (POST /webmail/?_task=login?_task=login&_action=login)
missed if like look
or do you want me to put all the lines here? matched and missed
they are identical
Released!
you need to adapt the regex, .*?\ will help you to create the regex
they are not identical (X-Forwarded-For: XXX.XXX.XXX.XXX) is the key of your issue
Hi!
i think, you don understand me.
create errors.log file and put two string
and
create roundcube-auth.local with your changes.
and test it
fail2ban-regex errors.log roundcube-auth.local
you are see 1 matched and 1 missed
but should be 2 matched.
Sorry my English …
Sorry but like I stated it was just an information, I did not spend time on it, you should adapt the regex to this case
in /etc/fail2ban/filter.d/roundcube-auth.conf
            ^\s*(\[\])?(%(__hostname)s\s*(roundcube:)?\s*(<[\w]+>)? IMAP Error)?: (FAILED login|Login failed) for .*? from .*\(X-Forwarded-For: <HOST>\)(\. .* in .*?/rcube_imap\.php on line \d+ \(\S+ \S+\))?$
restart fail2ban
systemctl restart fail2ban
this change will be overwritten by the next fail2ban update
