**NethServer Version: 6.8
**Module: OpenVPn
Hello, you first install nethserver. Configure a client and I roadwarrior presents the following problem.
The client connects well.
I successfully ping through the tunnel
Do not get to the hosts behind the tunnel, that is not masked.
the log say
Oct 19 20:29:12 nethfs kernel: Shorewall:ovpn2net:REJECT:IN=tun0 OUT=eth0 SRC=192.168.4.6 DST=10.100.85.113 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=60027 DF PROTO=TCP SPT=57493 DPT=22 WINDOW=65535 RES=0x00 CWR ECE SYN URGP=0
any ideas?
thanks since now
