How to allow external Owncloud Integration user name and password with Nethserver?
Thank you
What version of owncloud do you use? The config page has changed a lot with each new version.
Hi Robb,
Using the owncloud 9.1.1, and I can not connect to LDAP nethserver(Configuration incorrect). it seems the nethserver not allow.
Thank you
IIRC libuser
binds are allowed from localhost only. However authenticated binds should not be required because nethserver-directory (OpenLDAP) on ns7 allows anonymous binds from green networks, and ownCloud/nextCloud requires only browse permissions on LDAP.
If you want to connect from outside your LAN, create a dedicated user and bind with its credentials. Enable STARTTLS!
Hi Davidep
Yes, the Owncloud connect from green.
Here is my user detail
dn: uid=user01,ou=People,dc=directory,dc=nh
uidNumber: 1000
gidNumber: 1001
uid: user01
shadowWarning: 7
shadowMin: 0
loginShell: /usr/libexec/openssh/sftp-server
homeDirectory: /var/lib/nethserver/home/user01
shadowInactive: -1
shadowExpire: -1
gecos: user01
shadowFlag: -1
cn: user01
sn: user01
objectClass: posixAccount
objectClass: shadowAccount
objectClass: inetOrgPerson
mail: user01@mynetwork.com
shadowMax: 180
shadowLastChange: 17070
But still can not connect to the Nethserver
Did you try anonymous bind?
How to use anonymous bind?
Thank you
If you leave user DN and password empty you have anonymous bind
Now, the connection is OK, but I can not Verify settings and count users
Here is my configure
Server
xx.xx.xx.xx:389
leave user
password empty
dc=directory,dc=nh
Users
Login Attributes
Edit LDAP Query
(&(|(objectclass=inetOrgPerson))(|(uid=%uid)(|(mail=%uid))))
Groups
Only these object classes:posixGroup
Edit LDAP Query
(&(|(objectclass=posixGroup)))
Hi @Ya_Ley, have you tried this procedure http://docs.nethserver.org/it/v7/owncloud.html#configurazione-ldap-solo-aggiornamenti-da-versione-5 ?
p.s. NethServer 7 support NextCloud. It is possible to easily install it using web gui.
That’s the correct link in English
http://docs.nethserver.org/en/latest/owncloud.html?highlight=owncloud#ldap-configuration
HI
How create a dedicated user and bind with its credentials that allow the user and binds connect from remote ?
Thank you
I don’t know if our owncloud implementation on NethServer 7 creates a proper ldap user @alep
I suggest you try with the NextCloud module, it’s better implemented, tested and updated
AFAK owncloud for nethserver 7 does not exist anymore after the alpha version
Only nextcloud is supported
