I tested again the installation and the configuration of the “Account provider: Samba Active Directory” (I have at home a computer for tests), without to reboot the server between the installation of the package and the configuration of the Samba AD.
I had the same error at the end of the configuration process but I observed that the “START DC” button was still active.
Without leaving the page, I have enabled the “Create a bridge interface for the green network” and then I pressed the “START DC” button. After that, the process of the Samba AD ended without issues.
After that, I have created a new user, with password setting during the process, without issues.
Timeline in the “message” log:
19:20:02 - 19:20:19 → Install the Samba AD package
19:21:25 - 19:24:25 → First attempt of the Samba AD configuration
19:25:24 - 19:25:51 → Second attempt of the Samba AD configuration
19:27:21 - 19:27:14 → Changing the Admin password of the Samba AD
DHCP is not enabled now.
I don’t remember if was enabled during the installation of the NS.
This test is at home.
I have a wirelessrouter connected to the ISP through pppoe.
The WAN (192.168.0.17) of the NS 7b1 server is connected to the router’s LAN (192.168.0.1/24) and the GW is 192.168.0.2
I will try for the next installation of the NS 7b1 to connect the NS server to the Internet direcly, through pppoe (I will test in this case the pppoe protocol on NS. Is still available?), and I will use the wireless router through BLUE interface for my home wireless devices.
I’ve tried to install/configure Samba AD, twice, as follow:
Test 1
Install NS 7b1, from scratch
Install the updates
Edit the “Organisation contacts”
Edit the “Self-signed certificate”
Add the “Account provider: Samba Active Directory” package
Configure Samba AD
Test 2
Install the updates
Reboot the system
Configure Samba AD
Unfortunately, on both tests, I’ve encountered the same issue at the configuration of the Samba AD, no matter if the system was rebooted or not.
In both cases, the issue was solved in the same manner:
Without leaving the page, I have enabled the “Create a bridge interface for the green network” and then I have pressed the “START DC” button.
I will do another installation from scratch with “dc-ad.home.abt.ro” (not registered on the external Name Server as subdomain of “abt.ro”).
I will report after that.
I have created a shared folder with the settings as in the attached screenshot.
I thought that with this settings, as a guest (not joined into the domain), I will have full access to the folder, especially for write.
From Windows File Explorer, I can see the folder, I can open the folder but I cannot create file or folder inside him.
There is something wrong, or I’m wrong? Again!?
About certificate: it takes a few seconds to complete httpd-admin reload. After changing the server certificate wait a while, then reload the web page (F5).
The guest access requires (fake) credentials anyway. That means a fake user name and a fake password must be provided. Some times Win Explorer keeps presenting the cached domain credentials. Try by mapping a network drive with explicit credentials.
