LayLow
(LayLow)
July 13, 2020, 7:09am
1
Hi all, I hope all are fine.
I would be interested to test EthernetVPN on Nethserver. I know it is not supported due to required compilation, but the flexibility interests me.
Would you be able to hint me with some Nethserverish commands and do’s and don’ts on this page please?
https://wiki.contribs.org/SoftEther_VPN
e.g. signal-event portforwarding-update translates into…? etc etc
TIA
-HF
EddieA
(Eddie Atherton)
July 15, 2020, 4:44pm
2
If you install EtherVPN on NS, then portfowarding isn’t needed.
But what would be needed is to open the required ports in the firewall to allow incoming connections to the WAN (red) interface. The instructions can be found here: https://docs.nethserver.org/en/v7/third_party.html#firewall
** Update **
Looks like it would be all ports, except 5555 open to WAN and that one only open to the LAN, to allow the Windows Management console to connect.
Cheers.
HI HF,
Such a nice interface I cannot resist and try installation just to see.
I had to disable the complete firewall to connect but it is running, the Manager can connect.
I should try to bypass the SME stuf for the next step.
I am impressed !
Michel-André
LayLow
(LayLow)
July 16, 2020, 7:36am
4
Thanks guys, Let’s see if we can make this work and tested. I’ll have a go over the next few days today and post back.
TIA
-HF
