NethServer Version: 7.2009
Module: Ethernet
I have encountered a very frustrating problem: Nethserver has cut all ethernet connectivity. I cannot access the GUI to troubleshoot; I am stuck in CLI.
The ethernet card is RTL8125, for which I have installed the correct driver. I had the ethernet connection working fine up to yesterday. The GUI alerted me to one of my DNS hosts not responding. It then cut out after I began a system backup to Backblaze.
The only change in my network is a new ISP. I switched to TekSavvy (a Canadian provider) in order to open port 25 for e-mail. That switch required me to get a DSL connection with PPoE access. Nethserver appears to have automatically conigured PPoE, despite it not being instructed to make such a connection.
So far, I have attempted to reset the network configuration using network-recovery. I have also manually disabled the PPoE connection and my wireless device, so that the ethernet device is the only available external interface. Neither of these actions helped.
When I run nmcli dev status, I get:
enp5s0 ethernet unavailable --
When I run db networks show, I get:
enp5s0=ethernet
bootproto=static
ipaddr=192.168.0.160
netmask=255.255.255.0
network=192.168.0.1
onboot=yes
role=green
wlp3s0=ethernet
role=
Ifconfig reads:
enp5s0: flags=4099<UP,BROADCAST,MULTICOM> mtu 1500
ether ******************* txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16
I am going to be porting my installation off of the current computer to other hardware with a much older network card. This will hopefully solve my networking problem. In order to port the installation, however, I first need to resolve the network issue so that I don’t inadvertently wreck my new system.
Any ideas what could be done?
