/etc/rc.d/rc.local is not marked executable, skipping
Distribution: Rocky-9.2
NethServer Version: 8 beta
Module: none installed yet.
Quite often, I noticed on the server sreen, this kind of line repeated:
system-rc-local-generator[2603]: /etc/rc.d/rc.local is not marked executable, skipping
It looks like the system is trying to do something with rc.local.
QUESTION:
Is that important ?
Michel-André
I think you can ignore it: AFAIK rc.local is just for backward compatibility with previous distro versions. NethServer 8 does not use it at all.
Hi @davidep
Thank you for your reply.
I don’t mind at all in a Beta version, but aesthetically speaking those lines shouldn’t appear in a RC or Master version.
Michel-André
Silencing a single log message at boot doesn’t seem to me a sufficient reason to change that configuration file. Consider also that such change should be ported and tested on every other distro… So the general rule in NS8 development is: do not touch it unless it’s really necessary.
However some eye candies could be added to images, with no hurry at all.
Hi @davidep
I totally agreed with you and that is why I wrote that “I don’t mind at all in a Beta version”.
Michel-André
You could consider it as a distro/systemd bug too. Maybe someone is fixing it :wink:
Not a single message.
$ dmesg -T | grep -c marked
3868
I submit that changing the default mode on the file isn’t that big a deal.
